Hello and welcome to our Fiesta ST Forum community! Is this your first visit?
Register
User Tag List
Page 15 of 23 FirstFirst ... 57891011121314151617181920212223 LastLast
Results 141 to 150 of 222
Thread: Firestone Firehawk Indy 500
  1. #141
    Senior Member 83 Rep Points
    0%
    Rate Transaction
    Medals
    Earned First 5 Rep Points Earned First 25 Rep Points Earned First 75 Rep Points
    Join Date
    May 2016
    City
    LA
    State
    CA
    Country
    United States
    Posts
    1,087
    Mentioned
    14 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    83
    Quote Originally Posted by foodtruck View Post
    I'm curious, what pressures is everyone putting in these for 205/45-16?
    I used a couple psi less than stock for 205/45 17.
  2. #142
    Member 25 Rep Points Stormy's Avatar
    0%
    Rate Transaction
    Medals
    Join Date
    Apr 2016
    City
    Seattle
    State
    WA
    Country
    United States
    Posts
    113
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    25
    Hey all. Any idea what the "XL" means on these tires? I am looking at Firestone's website and the 205/40 and 205/45 R17 both say "XL", where many of the other sizes don't.
  3. #143
    Member 89 Rep Points
    0%
    Rate Transaction
    Medals
    Join Date
    Jan 2015
    City
    Viva Las Vegas!
    State
    NV
    Country
    United States
    Posts
    656
    Mentioned
    14 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    89
    Quote Originally Posted by Stormy View Post
    I believe it means Extra Load... as in heavy. You always want to check the load ratings of tires to make sure you aren't installing tires that aren't rated for the weight of your vehicle.
    2016 Fiesta ST - White Platinum Tri-Coat, Navigation, Recaro Package
    Active Shift Designs pedal spacer, Boomba - Symposer delete, brake deflectors, COBB - Accessport, RMM, Deadhook Motorsports - Race crash bar/intercooler, Diode Dynamics LED fogs, FSWerks Short-shift adapter, Huskyliner floor mats, MAPerformance - Cat-back, charge pipes, intake, Mishimoto trunk brace, Pierce Motorsports - 2-point lower brace, torsion bar brace, Suntek - 35F/17R tint, Rally Armor - Mud flaps, TB Performance cross member brace, Tune+ - IWG controller, tune, spark plugs, Xenon Depot H11 LED bulbs, Xpel film
  4. #144
    New Member 11 Rep Points S_Manley's Avatar
    0%
    Rate Transaction
    Medals
    Join Date
    Jun 2017
    City
    Portland
    State
    OR
    Country
    United States
    Posts
    12
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    11
    Hi Guys,
    I just got the Firehawk Indy 500's in 205/40/17 (OEM Size) put on the stock rims over the weekend. I am thinking that I am one of the first Fiesta ST guys in the country to have these put on.
    I know there has been a lot of grumbling (myself included) about a lack of good options for our stock size. After BFG discontinued the Sport Comp 2 in our size, we were left with precious few options for a summer tire. I was jumping for joy when these became available because it meant I didn't have to get the Yokohama S-Drives.
    This is my third set of tires on the Fiesta ST. The OEM Bridgestones lasted until about 18K. I then went to the Sport Comp 2's which lasted until about 38K, so I am getting pretty average wear for the ST. I will try to compare them to both, though I haven't had the Bridgestones for a year and a half and the BFG's were worn down to almost nothing:
    First is about setting expectations: this is a $90 tire. For the most part, I have the mantra that you get what you pay for, with few exceptions. I think the Indy 500 is an exception to that rule. Is it going to challenge the Star Specs or the RE-71R on the track or Auto-X? Most certainly not. Is it really even a challenge for the MPSS or PS4S? No, and it shouldn't be. However, I am looking at it as a comparison to what I have used and what's available in the Ultra-High and Max Summer category in our stock size.
    In comparison to the Sport-Comp 2's, the Firehawks fare quite well. They simply have more grip in the dry. I can do full throttle starts and there is no slip, no ESC intervention, nothing. It hooks and goes, through first and second. Granted, I am on a stock car with the exception of the Cobb RMM and Quick Shift Kit. The Sport Comp 2's would lose traction a bit more easily and you had to fight the wheel a bit more, even in the dry. There is NO QUESTION the Indy 500's would outcorner the Sport Comp 2's. Even brand-new before they are fully broken in, they have more grip.
    I haven't had a chance to test the wet grip yet (shocking in Portland). From everything I have read they are phenomenal in the wet. I will post my thoughts when we get rainfall next. I never had a big problem with either the BFG or the RE050A's in the rain, as long as you are responsible and reasonable.
    Where the Indy 500's don't quite stack up to Sport Comp 2's is in initial turn-in and mid-corner feedback. On the first point, I must clarify that the Indy 500's are brand new and still haven't been broken in and the Sport Comp 2's were worn. I do believe that the response will improve significantly as the tread blocks get a bit of wear, as they are full-depth right now which causes some tread roll which I am almost certain is what I am feeling. I haven't run these tires within an inch of their limits yet but when I do I will post my thoughts on their limits.
    The comment about mid-corner feedback echoes what Tire Rack said in their review against the Sport Comp 2's. They simply don't transmit as much feedback about the limits as the SC2's do, though the difference isn't that noticeable and if Tire Rack hadn't mentioned it I probably wouldn't have noticed. It doesn't detract from the experience and for street driving it shouldn't make any difference, and these aren't track tires. I am sure I will get used to it as the SC2's fade to a distant memory. The Indy 500's have more ability than the SC2's, though they don't always tell you they do through the steering wheel in the corners. They WILL pull you around. Moreover, I am sure the feel will improve as the tread gets a bit of wear.
    I am hesitant to compare the Indy 500's to the RE050A's as they are a different class of tire (Ultra-High vs. Max), but a lot of people are going to be coming from the RE050A's so I feel it prudent to do a limited comparison.
    If you are deciding between going with the RE050A's again or getting the Indy 500's: SAVE YOUR MONEY. Tire Rack has the RE050A's for $175 per tire. That is a rip-off. The Indy 500's are available for $90 per tire. They are not twice the tire that the Indy 500 is. Not even close. The Bridgestone is an OLD tire and it is very clear that development and technology has come A LONG way since 2004.
    The Bridgestone does have slightly better turn-in and I am guessing that the ultimate grip may be a little bit higher, but it would be negligible and most of us aren't going to be able to take advantage of that on the street. The Indy 500 is quieter, has a better ride, and I think will be better in the wet.
    The Indy 500's are currently the best option for anyone looking for a Ultra-High Performance or MAX summer tire in the stock size. All of the other options are either very old, very expensive, or do not perform very well. This is not a track tire and is obviously not a snow tire, though I have run summer tires and had no issues in rain or near freezing temps as I run them all year round: just be responsible.
    I will post more as they break in and I get to drive them in different conditions.
    Thanks!
    Sean
  5. #145
    Member 138 Rep Points Capri to ST's Avatar
    0%
    Rate Transaction
    Medals
    Earned First 5 Rep Points Earned First 25 Rep Points Earned First 75 Rep Points Earned First 100 Rep Points
    Join Date
    Dec 2015
    City
    CHAPEL HILL
    State
    NC
    Country
    United States
    Posts
    436
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    138
    Thanks, this is a very helpful review. It's also encouraging for those of us who committed to staying with oem sizes by investing in aftermarket 17" wheels.
    2016 KONA BLUE FIESTA ST
    RECAROS, 17 x 7 TD PRO RACE 1.2 WHEELS
    1995 ACURA NSX-T
  6. #146
    0%
    Rate Transaction
    Medals
    Join Date
    Apr 2016
    City
    Seattle
    State
    WA
    Country
    United States
    Posts
    113
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    25
    Quote Originally Posted by S_Manley View Post
    Hi Guys,
    Thanks!
    Sean
    Thanks for this. Really been eyeballing these as my RE050As are at ~16k and close to needing replacement. I'm up in Seattle so I'll be facing similar conditions to yours. Subscribing to follow your updates. These are an Ultra and with the glowing reviews from TR and many people on here I'm surprised you find them comparable to or inferior to the Bridgestones in the grip category. I expected they'd have the edge in all manners with the exception of indication at the limits.
  7. #147
    0%
    Rate Transaction
    Medals
    Join Date
    Jun 2017
    City
    Portland
    State
    OR
    Country
    United States
    Posts
    12
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    11
    Stormy,
    Let me give a bit more context. I haven't had the Bridgestone's for a while but the Indy's are VERY close to the level of the RE050A's, if not surpassing them. You will be able to get a much better comparison coming straight from the Bridgestone's than I will. I am trying to give the Bridgestone's the benefit of the doubt, because they are a class above and twice the price, though now that I think about it more, I am not sure that the RE050A's can outperform the Indy's.
    I would not even hesitate or look at any other tire. Now that the Sport Comp2 is discontinued, there really aren't any good choices left in the size except for the Indy 500's. And at the price, they are a no-brainer.
    Here is the thing: DO NOT WAIT. If you look at the Indy 500's in various sizes on TR, you will see that the availability is very limited. I was looking to go to a 205/45/16 and get the Indy's, and they are on a 3-4 MONTH back order. They can be very hard to find and Firestone does not seem to produce very many, much less in our stock size. I would order sooner rather than later and have them ready to be installed when need be.
    I cannot recommend Discount Tire enough. They are phenomenal. I am very picky about my wheels and tires and the shop here in Tigard exceeded my expectations and treated me and my car with the utmost respect. They have a store and regional office up in your neck of the woods in Lynwood.
    I'll keep you posted!
  8. #148
    0%
    Rate Transaction
    Medals
    Join Date
    May 2016
    City
    LA
    State
    CA
    Country
    United States
    Posts
    1,087
    Mentioned
    14 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    83
    @S_Manley Thanks for the review. Please let us know your feedback in the wet. I experienced great traction but the climate here is not quite as wet as yours and I'm fairly curious how well they handle in more extreme wet environments...
  9. #149
    0%
    Rate Transaction
    Medals
    Join Date
    Apr 2016
    City
    Seattle
    State
    WA
    Country
    United States
    Posts
    113
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    25
    Stormy,
    Thanks, man. The RE050As are astonishingly overpriced. They have poor reviews in the FiST community as well as on tire rack's site, and the criticisms mirror my own. The Indys are a category above the Bridgestones (ultra high vs max) and have far better ratings, so even at nearly half the price I would expect them to shine in comparison. There are other options out there like the Pilot Super Sports and the Potenza PP S04 for around 150 and 120 respectively. When the time comes I may very well throw the extra cash at the Michelin depending on the availability of the Indys and how fat my pockets are.
  10. #150
    Senior Member 782 Rep Points M-Sport fan's Avatar
    Ratings | Rate Transaction
    Medals
    Join Date
    Feb 2016
    City
    Solebury
    State
    PA
    Country
    United States
    Posts
    5,756
    Mentioned
    30 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    782
    Pretty much ALL of the actual OEM factory fitted sizes of a given tire model are overpriced on TR (and elsewhere), no matter how 'long in the tooth', out of date, or old tech they may be (or even past their "useful" date, why you see the 2013 and older leftovers being sold at a discount on TR).
    They were getting (or at least asking) STUPID prices for the ancient (and not so phenomenal even when they were NEW) RE92s not long ago simply because they were the factory tire on many preludes and Integras.
    Magnetic 2016 Fiesta ST base model
Similar Threads
  1. Firehawk Indy 500 215 45r17 like new $300 obo
    By svveeptheleg in forum For Sale
    Last Post: 04-14-2017, 05:42 PM
  2. Firestone Firehawk Wide Oval Indy 500
    By blue2turbo in forum Wheels & Tires
    Last Post: 01-07-2017, 10:08 PM
  3. Indy the 2016 FiST Build
    By Develonaut in forum Fiesta ST Build Projects
    Last Post: 08-24-2016, 05:42 PM
  4. Did Firestone align my car
    By Copeland9 in forum Suspension, Brakes & Chassis
    Last Post: 03-30-2016, 09:16 PM
  5. New FiST in Indy
    By IndyFiST in forum New Member Introduction
    Last Post: 06-11-2014, 01:46 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
