Hello and welcome to our Fiesta ST Forum community! Is this your first visit?
Register
See the top rated post in this thread. Click here
User Tag List
Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 41
  1. #11
    New Member 23 Rep Points spymac's Avatar
    0%
    Rate Transaction
    Medals
    Earned First 5 Rep Points
    Join Date
    Oct 2016
    City
    Central Valley
    State
    CA
    Country
    United States
    Posts
    45
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    23
    Guest-only advertisement. Register or Log In now!
    Quote Originally Posted by tacocat View Post
    Subbed. Is it possible to something like this using forscan?
    I'm not super familiar with the limitations of forscan, but I would imagine it could be done. However, it would take someone with the software to investigate and create a patch plus you would have to visit the dealer to have it applied.
    Basically what this guy would do:
    http://www.fordpimods.com/
    I would love to have the double honk disabled on the Fiesta :)
    I'm targeting a low cost, plug and play solution with no factory wiring modifications that can be installed in minutes with no special tools.
  2. #12
    Member 50 Rep Points
    0%
    Rate Transaction
    Medals
    Earned First 5 Rep Points Earned First 25 Rep Points
    Join Date
    Nov 2016
    City
    Milwaukee
    State
    WI
    Country
    United States
    Posts
    244
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    50
    In for options. I like the idea of a simple solution on this. Is it still a possibility to have "normal" (all the nannies on) more selectable with this, or is it just sport and all off? Just wondering as with all the snow and such and snow tires on, it's nice to have some esc assistance. also if anyone else drives the car, they're not freaked out when there's lights on the dash on a new car.
    Thanks for stepping up to do this!
    '16 Fiesta St (Recaros and a 'roof) HS auto-x car and HPDE toy
    '07 Civic SI Sedan (8400rpm of lulz. HPDE, TT, STX for autox, DD)
    '97 Neon ACR (Chump/LeMons car)
    '92 Spirit R/T (Lotus headed, G-Pa's BA Barkalounger)
    '87 Shelby CSX #669 ("stock" :) )
  3. #13
    0%
    Rate Transaction
    Medals
    Join Date
    Oct 2016
    City
    Central Valley
    State
    CA
    Country
    United States
    Posts
    45
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    23
    Quote Originally Posted by awwwww_shift View Post
    You will be able to select 'ESC ON' by cycling through the modes:
    VEHICLE START
    Mode: On
    MOD TURNS SPORT ON AUTOMATICALLY
    Mode: Sport
    [SINGLE ESC OFF PRESS]
    Mode: ESC OFF
    Mode: On
    If I end up doing the remote selector I'll include a default 'ON' function as well. Yeah you're right, this would be helpful in climates with extended periods of bad weather. This way you could keep ESC On by default and you would still be able to cycle though the modes and select ESC OFF using a single press instead of holding down for 5 seconds.
    Ohh and maybe a 'Valet' mode that would disable the ESC OFF button all together using the remote switch... that would be nice if you are letting someone borrow the car... well now I think I'm going to have to source a stealth selector switch
    Thanks for the input, always welcomed!
  4. #14
    Member 95 Rep Points Spaceman_Spiff's Avatar
    Ratings | Rate Transaction
    Medals
    Earned First 5 Rep Points Earned First 25 Rep Points Earned First 75 Rep Points
    Join Date
    May 2016
    City
    JeffCo
    State
    MO
    Country
    United States
    Posts
    469
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    95
    Quote Originally Posted by spymac View Post
    I considered it too but the pi platform is not well suited for this application. Plus you would still need an micro SD ($$) just to make it work. The sparkfun Arduino pro mini is perfect for this at only $10. No need to run a shutdown process, just power on/power off, almost instant boot up time, easy to program and keep running, no OS to get corrupted etc.
    Fair enough.
    Sent from my Spaceship
    '16 FiST: White Platinum, Black wheels.
  5. #15
    Member 159 Rep Points Waterfan's Avatar
    0%
    Rate Transaction
    Medals
    Earned First 5 Rep Points Earned First 25 Rep Points Earned First 75 Rep Points Earned First 100 Rep Points
    Join Date
    Sep 2014
    City
    SoCal
    State
    CA
    Country
    United States
    Posts
    560
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    159
    I regret I have only 1 Like to give (on every 1 of spymac's posts) :)
    2014 Fiesta ST, Oxford White, Recaros, Navigation, Symposer Delete ($4 Expansion Plug), FSWerks Short Shift (25% setting), COBB AP3 (OTS 91 v220), Fiesta Aluminum Spare Tire (-16.6 lbs), 205/45-16 RE760 on 16x7 ET40 Maxxim Winner (-16.4 lbs), K&N Air Filter
  6. #16
    0%
    Rate Transaction
    Medals
    Join Date
    Oct 2016
    City
    Central Valley
    State
    CA
    Country
    United States
    Posts
    45
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    23
    Thought I would post an update on the progress since there does seem to be a bit of interest in the project (glad its not just me!)
    After some of the feedback I've been looking into a selector function to set the default mode. This would allow the end user to select the default mode to suit their need. Some use cases:
    During summer I want ESC off as my default
    During winter months I want full nannies
    I want sport mode as my default but want the ability to set ESC OFF as the default for track days
    So originally I was considering a separate switch or on-board selector to change modes but then it kinda hit me. The Arduino has built in EEPROM! Basically like a tiny hard drive that will save values when you turn the board off. This will allow a value to be saved that will be read on startup to determine the mode selection used (no physical switch required). So we could set the default mode using the ESC OFF button that will be saved for the next startup! Here is my thought on how to activate/set the default mode:
    Set sport mode (dash light on)
    Hold down ESC OFF for 10 seconds to enter programming mode (dash light turns off)
    Press the ESC OFF to set default mode based on the following:
    1 press = ESC ON (full nannies)
    2 press = Sport Mode
    3 press = ESC OFF
    4 press = Can I borrow your car? / Dealership mode(see below)
    Mode is set after 5 second timeout
    Dash light blinks number selected
    Dash light off to confirm programming mode exit
    Can I borrow your car / dealership mode:
    This mode will disable your ESC button for situations like loaning your car to a friend. Or when you take the car in for service to ensure the dealer techs don't have too much fun without your consent. (Bonus points of the service writer notes a defective ESC button on your service order!) Dealership mode can be disabled by setting the default mode again during the first minute the car has been started, or something like that.
    I've got most of the programming done at this point but I'm sure there will be some additional tweaks once its installed for testing. This project is turning out to be a lot of fun so stay tuned for updates! Thanks to all who've subbed, asked questions and given feedback! As always, I welcome any suggestions, community involvement makes a better final product for everyone!
  7. #17
    0%
    Rate Transaction
    Medals
    Join Date
    Nov 2016
    City
    Milwaukee
    State
    WI
    Country
    United States
    Posts
    244
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    50
    3 press = ESC OFF
    Very nicely done! That just answered every question I could have asked about this. I'm interested in one, possibly as the kit, more than likely as an assembled unit.
    Kudos!
  8. #18
    Senior Member 866 Rep Points Sourskittle's Avatar
    0%
    Rate Transaction
    Medals
    Join Date
    Apr 2014
    City
    Lakeland
    State
    FL
    Country
    United States
    Posts
    4,567
    Mentioned
    138 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    866
    I want to buy this. Take my money.
    325Whp on E50/meth injection ( NOT BHP )
    315Whp on E30 no Meth
    110mph trap speed
    Cyborg Stock Upgraded Turbo setup
    http://www.fiestastforum.com/forum/t...charger-system
  9. #19
    Member 44 Rep Points
    Medals
    Join Date
    Feb 2016
    City
    Morton Grove
    State
    IL
    Country
    United States
    Posts
    235
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    44
    Quote Originally Posted by Sourskittle View Post
    I'll take one as well
    Deporacing DP, Deporacing IC, Mountune CBE, Damond OCC, GFB DV+,Cobb RMM, and tuned by Stratified
  10. #20
    Member 84 Rep Points FORZDA 2's Avatar
    0%
    Rate Transaction
    Medals
    Join Date
    Oct 2014
    City
    Gloucester
    State
    VA
    Country
    United States
    Posts
    262
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    84
    Hmmmm? I'll take one as well.
    '14 Ford Fiesta ST Molten Orange Yeah, I've made a few mods... It's a Seriously Fun Pocket Rocket Toy
Similar Threads
  1. Video: Oil Change
    By kennybobenny in forum Maintenance, Warranty Issues & Troubleshooting
    Last Post: 09-14-2016, 10:28 PM
  2. Back Road video and MAP CBE sound video
    By MPA in forum Fiesta ST Photos & Media
    Last Post: 04-15-2016, 11:03 PM
  3. In Car Rally Video
    By iso100 in forum Fiesta ST Photos & Media
    Last Post: 08-30-2014, 08:34 AM
  4. New ATP video
    By Colin1337 in forum EcoBoost Engine Upgrades
    Last Post: 07-03-2014, 10:57 PM
  5. New Cobb Video
    By Kip2MyLou in forum Performance Tuning
    Last Post: 02-25-2014, 04:34 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
