Hey guys,
I just installed a full set of these - https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1. I did all the interior lights and the plate lights. They work very well and are VERY bright. They still dim in and out when you lock and unlock, which is nice. Just a heads-up, they are polarity sensitive so if you install them, test each one before you bolt your assemblies back together, especially the rear seat cluster. I had to switch a few after the first time. Also, they just barely fit in the front seat cluster (with sunroof). The LEDs on the sides rub against the edges of the hole in the reflector, it took some force/finesse to get them seated. Cheers.
