Cobb TC 1-8
Miami
Which setting have you guys had the most success with?
How does setting one (sport mode default) differ from TC on from factory?
I have found 4-5 to be running well.
On a different note why would one use the soft cut LC vs the hard cut? I have only tried the hard cut set to 3100-3300. Anyone run that much higher?
Thanks
B
Miami
Thread Starter #2
Nobody has played with the new features? I figured by now you guys would be chiming in on what slip is the best or LC setting is ideal.
My default is 1 is there a way to default to higher numbers?
Gatineau
I should be receiving my AP today or tomorrow, so I can't talk about it yet, but from what I've read it always default to 1 BUT 1 is not actually one in relation to the others, but simply the first position and then 2 through 8 is less slip to most slip.
I can't find the info for the Cobb itself, but Stratified has an handy diagram:Stratified (scroll down a bit on the page, this is true for both ST)
I expect it's very similar for the Cobb version of it.
Based on that diagram, Stratified is by default pretty much in between 4 and 5 like you like it.
I'm for sure going to give it a try when I can as I'm curious how it will feel.
