I'm not getting over 16.5 on my fist. Uninstalled AP , pressurized from hot pipe to cold side hose holds 10 psi , loosened and tightened all clamps. Surges at 2500 rpm steady throttle. Can this be diagnosed through logging ? I have GFB DV+ and removed and inspected it. Bad wastegate actuator or boost control valve ? Dealer service dept says it's meeting all demands from ecu. Won't even break tires loose.
