Noise in top gear
Alexandria Bay
My transmission tends to make a whining noise on throttle in 6th gear. Won't do it in any other gears but 6th. Also the noise is only when on throttle. Called Ford searched TSB's and found nothing. Have found people online who are having the issue just no resolve as of right now.
Miami
Most likely a bearing. Seems to be common issue with these transmissions. Ford should replace if you're under warranty.
