Ok thanks. Mine has the heater issue as well took it to Richmond , they didn't flash it said it was up to date. Still the same problem no heat up to 27c. Only 28c up then you get heat but too much, no in between. They said to just keep on observing the problem. Asked them if the module needed to be changed , they would only change it if there was no heat at all
