Please email
support@cp-e.com with a copy of your invoice from where you bought it and they can send you a PDF of the directions.
Basically cut off the line going from the intake to the T in the evap line, replace it with supplied hose (the one with the check valve in it).
Remove the line from the cold side charge pipe and cap it off with supplied cap fitting.
PM me if you need anything else. Thanks
