I am getting too old to be crawling around on the garage floor. I need a lift.
One of the nuts is trashed, didn't want to come off, it finally did. Looks like the threads on the dp are boogered.
Installing the aftermarket system didn't go any better. The rear section wouldn't stay together (slip fit) so I couldn't get the system bolted up to the dp to even attempt to adjust it.
Arrrrg I finally gave up. It was supposed to be an easy install, only two nuts and a couple pipes right. Fiiick
