Hi everyone, I have been running the new tester DP for Ron for a couple of weeks. I wanted to document my thoughts, and show some pics / videos.
First off, this is a 3" Catless DP that tapers down to 2.5". It has a bracket to attach to your stock DP support, as well as an Extra bung if you want to run a wideband.
My thoughts on the DP:
Fit and finish: The welds are good enough for the price point and the overal fit and finish of the DP is good. The DP support is very nice as it gives me peace of mind that less stress will be put on the turbo mounting bolts.
Installation: The DP installed very easily. I found no issues with the fitment. The stock turbo metal gasket went on nicely, and the two open turbo attachments made it easy to install. You can start the 2 bottom accessible bolts, slide on the DP, then install the last bolt from the top near that is not slotted to slide on. The o2 sensor screwed in nicely with no issues. The exhaust side comes with a metal oring of sorts, as well as a exhaust gasket. Ron and I went back and forth thinking about which way to install the Oring. If you look at the photos, you will see one side is flat, one side is tapered. I chose to install the tapered side facing the DP, and the flat side facing the catback. My reasoning: it will mushroom the tapered side a bit into the DP and create a strong seal. If you install the tapered side out, it would press into the exhaust gasket strangely. I have had NO issues with exhaust leaks.
Sound: The sound is pretty amazing. I am currently running a Cobb Cat back. Before, you couldn't hear the turbo spooling and the exhaust note was a bit artificial. With the new DB, it is much throatier, and you get an awesome turbo spooling sound from inside the cabin and on the outside. Videos are below.
Power: I am currently running an e30 tune from Stratified. I have received my first base tune and am in the process of datalog revisions. But from my butt dyno, the power is much stronger on the top end, it doesn't fall on it's face as much over 4500 RPM's. I will update as I get my final tune revised. I am pushing over 25 PSI right now and will most likely make around 26 PSI.
Photos of the DB and install:
Metal Oring with tapered side facing in (how I installed)
Met Oring with tapered side facing catback (I did not install this way)
The DP bracket from below
With the mount loosely installed to the car, I took a bolt and ran it through as it doesn't perfectly line up, it will be at a slight angle. Once you have it ran through the hole on the DP bracket, you can tighten down the bolt/nut going through the DP's bracket, then tighten down the bolts on the car's DP bracket. This will all snugly tighten down and the DP will be perfectly supported.
Note: the new bolts will be a bit longer. You may be able to use the stock Metal long Orings that are on the dp adapter, but I didn't.
Videos:
Before:
[video=youtube;C4LzkQoVME0]https://www.youtube.com/watch?v=C4LzkQoVME0&ab_channel=codys[/video]
After:
[video=youtube;HZuv3tH3ZUc]https://www.youtube.com/watch?v=HZuv3tH3ZUc&ab_channel=codys[/video]
Feel free to ask me any questions you may have!
Videos:
Before:
After:
