About two months ago I felt my 2015 Fiesta ST have a sudden loss of power. More specifically in 3rd gear and up. It feels like i hardly hit boost and less acceleration. Also, the BOV whoosh noise is noticeably lower. There is no check engine light. I have checked and tightened all pipes and there is no leaks. The car has has Cobb Intercooler, Cobb intake, Cobb RMM, Turbosmart BOV, Boomba symposer delete, FS werks exhaust. I purchased the car with most of these part and i suspect it had an acessport at one point. Im not sure if this could be the problem. I replaced the Boost solenoid as i suspected it might have failed but no luck. I have a odb2 blutooth transmitter that i use with Odb fusion app. Im not sure if the boost reading i am getting from it is accurate but the boost wont go past 5psi.
Any help will be greatly appreciated.
