DHM head studs Torque specs and sequence
Perfblue15
Canyon country
So, I lost the spec sheet on how to install my head studs and my builder is ready to install my cylinder head onto my built shortblock. I was hoping maybe someone on this forum purchased DHM head studs and could post pictures of the sheet with the sequence and torque specs.
Thanks in advance!
Sent from my SM-G955U using Tapatalk
Quisp
Davenport
I found one on eBay and he posted instructions in the description.
Can I install these without removing the cylinder head?
Yes, However you must remove one bolt at a time in the OEM sequence and torque the stud to 70ft/lbs. Once all studs are installed you must loosen one nut at a time in OEM order lube it and torque it to 70ft/lbs just like in the instructions.
hamilton
Thanks in advance!
NOTE: Make sure that no fluids are present in the cylinder head bolt threaded bores.
Torque :
Stage 1: 44 lb.in (5 Nm)
Stage 2: 133 lb.in (15 Nm)
Stage 3: 26 lb.ft (35 Nm)
Stage 4: 90°
Stage 5: Tighten an additional:: 90°
This is the spec from ALLDATA, not sure if the DHM studs are different.
Perfblue15
Perfblue15
Canyon country
I just called arp and confirmed this. Thank you so much.
