Intake air temperature sensor 1 circuit high code
Ellsworth afb
Just installed my 2j racing cold air intake( with a lot of headscratching) and now I'm receiving this code. I have 2017 fist so I ordered the cobb tuning adapter kit as instructed by 2j and I think I have it installed correctly although I probably don't 😂any advice in this code?
Beltsville
most likely the wiring in the "MAF" sensor, which is really only used as a temp sensor on U.S. models. I would make sure everything is plugged in and delete the code and see if it comes back. Sometimes, if the car is on when a sensor is unplugged, the CEL will stay on until you reset. Then if it does go and double check our wiring.
