DIY-er here.
First of all, there are many different (versions of) Vvivid materials. Some are simply garbage though. Great price and I would recommend them for small projects, but for something as big as a roof, forget it. I wouldn't risk using them for fear of getting one of the garbage versions. Their adhesive is way too strong and it makes their air channels redundant as you are unable to push out the air bubbles because of how strong the adhesive is. If you are a professional, maybe it's worth it. But as a DIY that probably only wants to buy one roll and not have issues the first time, I would suggest to avoid them. I tried using Vvivid and it was a nightmare. Wasted 8+ hours of my life.
I went with 3M. More expensive, but so much more worth it. Used the exact same technique and got my roof wrap done in about 3 hours.
Also, for the roof trim, it's unnecessary to remove them. Use one of those plastic auto trim tools to move the rubber and tuck the vinyl wrap in. Hard to explain, but you'll get it if you take a close look at your roof trim.
