Bilstein PSS OEM foam?
Upstate
Just installed the Bilstein PSS kit but looking back on it the directions didn't indicate to reuse the foam pad on the front struts, so I didn't, is this correct? Or am I getting the spring compressor back out?
TERAWR
Upstate
Foam pad? The bumpstop?..if so, no
In the rear there are foam pads that go on the top spring perch, I got mixed up with where they came from. So, I figured it out after taking things back apart again, much work for nothing I suppose.
What started this quest was that the ride height was uneven by a lot, turned out the rear driver was a little too high making the front passenger sit a little too low.
