FS: Epic CP-E intake for sale 2014-2015 model, color black
Trader history for jeff (2)
jeff
Evans
Product Description: Epic CP-E intake for Fiesta ST model 2014-2015, color black
Price: $265 picked up or $285 shipped
Images: See below
Shipping Details: Free pickup or shipping quote priced to CONUS only
Contact Information: PM me and I'll send you my Paypal info.
YOU yes YOU need this epic CP-E intake. It's the blingiest, the swooshiest, the snazziest...when you open your hood everyone will notice this intake and they will comment and become your friend. You will be the star of the car show. And, it will lower your intake air temps and probably increase your airflow mass and your pride of life. There are more horsepower and torques to be had as well. My MPG increased as well once I installed this. It also caused me to get in several arguments with some testy know-it-alls, but they barely post here anymore so you probably won't have that issue if you opt to declare the wonders of your new CP-E intake.
But in all seriousness, after 2 years with my lovely CP-E I've decided to go with a different setup, I'm de-blinging and de-noising my car and moving in a more practical direction. So, someone will enjoy this. It's in great shape, all parts are here including an unused CP-E sticker. I also have the detailed full-color install instructions. The intake plexiglass has no scratches, and I just cleaned the filter. It's the oil kind but you can run it dry if you like, or re-oil it, the choice is yours. There are a few scratches as is typical with these since they fit so tightly, but they are all hidden from view once installed. The third pic details (again, check the recent thread on this) the usual gash in the induction pipe area, but it's not that deep and once you install it you can put a bumper or piece of velcro there to prevent rubbing as I did (I didn't do this until I realized it was an issue, hence the gash, but it gashed no further...the truth is it can be installed in such a way that it doesn't rub anywhere, I've installed it more than once and found this to be true, it takes a bit of finagling). Like I said it's in great condition, once installed it will look 99.9% brand new.
These are $379ish shipped from Ron at Whoosh or CJ Pony parts so you're saving an INCREDIBLE 20ish% by buying from Jeff!!!!!!
Also this is the 2014-2015 model, I believe there is a part you can by from CP-E to make it fit the 2016+ models, but you'll need to research this.
That's all I can think of.....pics below. If you want more pics let me know and I'll take whatever angle you want...but as I said this is in great condition.
PM me if interested...for pickup I'll need a Paypal payment in advance if you want me to hold it, these are a hot commodity and I'm not going to turn down potential buyers for a maybe cash/pickup sale. I'm in Evans GA close to I-20 and will drive a short way to meet you if necessary. Heck, if you're local I'll help you install, just buy me lunch and we're on it!!!
Thanks for looking!!!
Details from CP-E website (click red for link):
The Fiesta ST is a well-rounded car in just about every aspect, and the intake system is too. The stock intake system is designed well, and the community sees that. Still cp-e™ felt that they could take the good & the bad from the stock system, and make it even better. After a long engineering process, cp-e™ is proud to release the Ford Fiesta ST xCel[]™ Ram Air Box Intake for the Fiesta ST.
Laser Cut Airbox
• CNC formed AirBox
• Airbox made from Stainless Steel(Great Thermal Insulator)
• Full 3” Mandrel Bent Aluminum Tube
• Billet aluminum CNC machined Bellmouth
• Clear plexi-glass window (ships with orange peel-off protective coating)
• Widemouth Air Filter in DflowTM or SynOil™
• Laser cut Brackets and Bungs in OEM locations
• Available in Satin Black or Race Red
• Ram Air snorkel for additional airflow.
• Abrasion resistant & laser cut Plexiglass for easy filter maintenance/viewing
• CNC lathed feet on box for mounting
• Laser cut and CNC bent bracket provided to relocate the hood prop mounting
• Made in the U.S.A.
• Lifetime Warranty
ONLY FITS 2014-2015 VEHICLES
ATTENTION NON-USDM Customers: if your car uses the mass air sensor you will need a tune that accounts for the added air volume. USDM cars have a mass air sensor in them however they only use it for intake air temperature measurements so there is no tune required for USDM cars.
PRODUCT DESCRIPTION:
Available powder coated in Satin Black, Ford Race Red the αIntake[]™ Ram Air Box Intake offers the most well thought out solution to getting air to your turbo yet. The αIntake[] Intake comes with a full 3.00” mandrel bent tube. Welded onto the tube are a CNC-lathed port for the PCV system and a CNC laser cut and former bracket. In addition there is also a mass air sensor adaptor welded to the tube that allows you to bolt the stock mass air sensor in place. This adaptor is CNC milled from billet aluminum and contoured to fit the tube perfectly.
The intake tube then attaches to the air box through a 5-ply silicone elbow and a CNC-Milled aluminum bellmouth. This velocity stack bellmouth smoothly compresses the air from 4.00” to
© 2015 Custom Performance Engineering All Rights Reserved | αIntake[]™ 1 of 2
3.00” providing a minimal amount of energy loss which translates to a higher air speed through the tube. The included 4.00” air filter is specially designed by cp-eTM to give the most free flowing air flow possible, with your choice between DflowTM or SynOilTM.
Part of what makes the stock intake system well-rounded is the great design of the stock box. It brings in cool air efficiently, and isolates the filter from the hot air in the engine bay. Where the stock box lacks is where the cp-eTM αIntake[]™ shines above all. The αIntake[]™ box is laser cut and CNC-bent 18 gauge stainless steel. Stainless steel is great for this application for not only its resistance to corrosion, but also its thermal properties allow the interior of the box to stay cool, even when the box itself heats up. The box utilizes the stock fresh air duct, and also sucks up cool fresh air from the bottom mounted snorkel tube. The box is topped off by clear plexi glass to seal the filter from the heat, providing a sweet view and easy access to the filter. Not only is it laser cut for perfct fitment, but also abrasion resistant. Lastly, the box easily mounts in the stock location with the laser cut brackets and CNC-lathed mounting feet.
LOTTO PICS:
jeff
jeff
Evans
Thread Starter #2
Saturday the 14th bump! No takers on Friday the 13 I see...hah!!! Don't be scared to spend money!!!
Take a look at this thing install on my car...what a beauty!!!
jeff
jeff
Evans
Sunday bump! Overly well-packed in epic fashion and ready to ship out!!!
jeff
jeff
Evans
Tuesday bump!
Buy this wonderful intake and I'll throw in these ST wheel cap covers and either one of these license plate frames!!!!
Bowie
Every time I buy something a great deal pops up!
jeff
jeff
Evans
Pre-weekend bump.....I'm heading to the woods to camp early tomorrow, someone scoop this up over the weekend!!!
Price dropped by $10!!!!
Northridge
Bump for a killer deal! I actually really like the 1.6 plate frame. Wish these worked on 2016's!
jeff
jeff
Evans
They do. Just have to get the evap harness from the earlier years.
Thanks guys!
Weedend bump!!!
Anyone get that? Weed end? I know I'm a day late, but....
WEEKEND bump!!!
XR650R
Eerie
Yeah, man! It's 4:20 somewhere! [goofydrunk]
Wow, man. What a concept!
jeff
jeff
Evans
Thread Starter #12
Monday bump, price dropped!!!
Boxed up and ready to ship your way!!!!!
jeff
jeff
Evans
Thread Starter #13
Weekend bump!
Price dropped to $285 shipped!!!
