Ford FIESTA ST Specifications
PEFORMANCE AND ECONOMY
[table="width: 800, class: outer_border, align: left"]
[tr]
[td] [/td]
[td] [/td]
[td] [/td]
[td] Fuel consumption
l/100 km (mpg) [/td]
[td] Performance [/td]
[/tr]
[tr]
[td] Engine [/td]
[td] Power
(PS) [/td]
[td] CO2
(g/km) [/td]
[td] Urban [/td]
[td] Extra
Urban [/td]
[td] Combined [/td]
[td] Max speed kph (mph) [/td]
[td] 0-100 kph
0-62 mph
(sec) [/td]
[td] 50-100 kph
31-62 mph
(sec)* [/td]
[/tr]
[tr]
[td] 1.6 EcoBoost (6-sp manual) [/td]
[td] 182 [/td]
[td] 138 [/td]
[td] 7.9 (35.8) [/td]
[td] 4.8 (58.9) [/td]
[td] 5.9 (47.9) [/td]
[td] 220 (137) [/td]
[td] 6.9 [/td]
[td] 6.4 [/td]
[/tr]
[/table]
* In 4th gear
WEIGHTS
[tr]
[td] Kerb
weight (kg)# [/td]
[td] Gross Vehicle Mass
(kg) [/td]
[td] Gross Train Mass
(kg) [/td]
[td] Max. Towable Mass (braked) (kg) [/td]
[td] Max. Towable Mass (unbraked) (kg) [/td]
[/tr]
[tr]
[td] 1163 [/td]
[td] 1575 [/td]
[td] N/A [/td]
[td] N/A [/td]
[td] N/A [/td]
[/tr]
[/table]
# Represents the lightest kerbweight assuming driver at 75 kg, full fluid levels and 90% fuel levels, subject to manufacturing tolerances and options, etc., fitted.
Towing limits quoted represent the maximum towing ability of the vehicle at its Gross Vehicle Mass to restart on a 12 per cent gradient at sea level. The performance and economy of all models will be reduced when used for towing. Nose weight limit is a maximum of 50 kg on all models.* Gross Train Mass includes trailer weight
DIMENSIONS
[tr]
[td] Dimensions (mm) [/td]
[td]3-dr [/td]
[/tr]
[tr]
[td] Exterior [/td]
[td] [/td]
[/tr]
[tr]
[td] Overall length [/td]
[td] 3975 [/td]
[/tr]
[tr]
[td] Overall width with/without mirrors [/td]
[td] 1978/1709 [/td]
[/tr]
[tr]
[td]Overall width with folded back mirrors [/td]
[td] 1787 [/td]
[/tr]
[tr]
[td] Overall height [/td]
[td] 1456 [/td]
[/tr]
[tr]
[td] Wheelbase [/td]
[td] 2489 [/td]
[/tr]
[tr]
[td] Interior [/td]
[td] [/td]
[/tr]
[tr]
[td] Front headroom [/td]
[td] 991 [/td]
[/tr]
[tr]
[td] Front max legroom (lowest rearmost seating posn) [/td]
[td] 1111 [/td]
[/tr]
[tr]
[td] Front shoulder room [/td]
[td] 1350 [/td]
[/tr]
[tr]
[td] Rear headroom [/td]
[td] 953 [/td]
[/tr]
[tr]
[td] Rear legroom [/td]
[td] 823 [/td]
[/tr]
[tr]
[td] Rear shoulder room [/td]
[td] 1300 [/td]
[/tr]
[tr]
[td]Luggage capacity (litres)? [/td]
[td] [/td]
[/tr]
[tr]
[td]5-seat mode, laden to package tray (with mini spare) [/td]
[td] 276 [/td]
[/tr]
[tr]
[td]5-seat mode, laden to package tray (with tyre repair kit) [/td]
[td] 290 [/td]
[/tr]
[tr]
[td]2-seat mode, laden to roof (with mini spare) [/td]
[td] 960 [/td]
[/tr]
[tr]
[td]2-seat mode, laden to roof (with tyre repair kit) [/td]
[td] 974 [/td]
[/tr]
[tr]
[td] Fuel tank capacity (litres) [/td]
[td] [/td]
[/tr]
[tr]
[td] Petrol [/td]
[td] 42 [/td]
[/tr]
[/table]
? Measured in accordance with ISO 3832. Dimensions may vary dependent on the model and equipment fitted.
STEERING
[tr]
[td] System [/td]
[td] Electronic Power Assisted Steering (EPAS), rack-and-pinion, 2.32 turns lock-to-lock [/td]
[/tr]
[tr]
[td] Ratio [/td]
[td] 13.69:1 [/td]
[td] [/td]
[/tr]
[tr]
[td] Turning circle (m) [/td]
[td] 11.2 [/td]
[td] [/td]
[/tr]
[/table]
WHEELS AND BRAKES
[tr]
[td] [/td]
[td] Front [/td]
[td] Rear [/td]
[/tr]
[tr]
[td] Braking [/td]
[td] Hydraulically operated dual-circuit system with diagonal distribution. Vented front discs, solid rear discs. Electronic four-channel anti-lock braking system (ABS) with electronic brake-force distribution (EBD) and Emergency Brake Assist (EBA) [/td]
[/tr]
[tr]
[td] Disc dimensions (mm) [/td]
[td] 278 x 23 [/td]
[td] 253 x 10 [/td]
[/tr]
[tr]
[td] Piston calliper dimensions (mm) [/td]
[td] 54 [/td]
[td] 34 [/td]
[/tr]
[tr]
[td] Wheels [/td]
[td] 7.5J x 17 light alloy metal 5-spoke [/td]
[/tr]
[tr]
[td] Tyres [/td]
[td] 205/40 R17 [/td]
[/tr]
[/table]
CHASSIS
[tr]
[td] Front [/td]
[td]Rear [/td]
[/tr]
[tr]
[td] Independent suspension with McPherson struts supported by L-shaped lower wishbones connected to vehicle sub-frame. Separate load paths for spring
and damper [/td]
[td]Torsion beam suspension with progressive tracking control. Coil springs positioned under-floor with separate monotube shock absorbers [/td]
[/tr]
[tr]
[td] 3-mode Electronic Stability Control (ESC) and enhanced Torque Vectoring Control (eTVC) [/td]
[/tr]
[/table]
ENGINE DATA
[tr]
[td] [/td]
[td] [/td]
[td] 1.6-litre EcoBoost
(182PS) [/td]
[/tr]
[tr]
[td] Type [/td]
[td] [/td]
[td] Inline four cylinder turbo petrol, transverse [/td]
[/tr]
[tr]
[td] Displacement [/td]
[td] cm3 [/td]
[td] 1596 [/td]
[/tr]
[tr]
[td] Bore [/td]
[td] mm [/td]
[td] 79.0 [/td]
[/tr]
[tr]
[td] Stroke [/td]
[td] mm [/td]
[td] 81.4 [/td]
[/tr]
[tr]
[td] Compression ratio [/td]
[td] [/td]
[td] 10.1:1 [/td]
[/tr]
[tr]
[td] Max power [/td]
[td] PS (kW) [/td]
[td] 182 (134) [/td]
[/tr]
[tr]
[td] [/td]
[td] at rpm [/td]
[td] 5700 [/td]
[/tr]
[tr]
[td] Max torque [/td]
[td] Nm [/td]
[td] 240 [/td]
[/tr]
[tr]
[td] [/td]
[td] at rpm [/td]
[td] 1600-5000 [/td]
[/tr]
[tr]
[td] Valve gear [/td]
[td] [/td]
[td] DOHC
with 4 valves per cylinder [/td]
[/tr]
[tr]
[td] Cylinders [/td]
[td] [/td]
[td] 4 in line [/td]
[/tr]
[tr]
[td] Cylinder head [/td]
[td] [/td]
[td] Cast aluminium [/td]
[/tr]
[tr]
[td] Cylinder block [/td]
[td] [/td]
[/tr]
[tr]
[td] Camshaft drive [/td]
[td] [/td]
[td] Timing belt [/td]
[/tr]
[tr]
[td] Crankshaft [/td]
[td] [/td]
[td] Cast iron [/td]
[/tr]
[tr]
[td] Engine management [/td]
[td] [/td]
[td] Bosch [/td]
[/tr]
[tr]
[td] Fuel injection [/td]
[td] [/td]
[td] High pressure direct fuel injection system with 6 hole injectors [/td]
[/tr]
[tr]
[td] Emission level [/td]
[td] [/td]
[td] Euro Stage 5 [/td]
[/tr]
[tr]
[td] Turbocharger [/td]
[td] [/td]
[td] Fixed geometry turbo with active wastegate and active compressor recirculation valve [/td]
[/tr]
[tr]
[td] Lubrication system [/td]
[td] [/td]
[td] Pressure-fed with variable displacement pump and full flow oil filter [/td]
[/tr]
[tr]
[td] System capacity with filter [/td]
[td] litres [/td]
[td] 4.1 [/td]
[/tr]
[tr]
[td] Cooling system [/td]
[td] [/td]
[td] Water pump with thermostat and valves, with thermal management system [/td]
[/tr]
[tr]
[td] System capacity* [/td]
[td] litres [/td]
[td] 5.5 [/td]
[/tr]
[tr]
[td] Transmission [/td]
[td] [/td]
[td] Durashift 6-speed (B6) manual [/td]
[/tr]
[tr]
[td] Gear ratios [/td]
[td] [/td]
[/tr]
[tr]
[td] [/td]
[td] [/td]
[td] [table="width: 300, class: align: left"]
[tr]
[td] 6th 0.690
5th 0.821 [/td]
[/tr]
[tr]
[td] 4th 1.032 [/td]
[/tr]
[tr]
[td] 3rd 1.357 [/td]
[/tr]
[tr]
[td] 2nd 2.048 [/td]
[/tr]
[tr]
[td] 1st 3.727 [/td]
[/tr]
[tr]
[td] Reverse 3.818 [/td]
[/tr]
[tr]
[td] Final Drive 3.824 [/td]
[/tr]
[/table][/td]
[/tr]
[/table]
[tr]
[td] [/td]
[td] [/td]
[td] [/td]
[/tr]
[tr]
[td] Engine [/td]
[td] Power
(PS) [/td]
[td] CO2
(g/km) [/td]
[td] Urban [/td]
[td] Extra
Urban [/td]
[td] Combined [/td]
[td] 0-100 kph
0-62 mph
(sec) [/td]
[td] 50-100 kph
31-62 mph
(sec)* [/td]
[/tr]
[tr]
[td] 182 [/td]
[td] 138 [/td]
[td] 6.9 [/td]
[td] 6.4 [/td]
[/tr]
[/table]
* In 4th gear
WEIGHTS
[tr]
[td] Kerb
weight (kg)# [/td]
(kg) [/td]
(kg) [/td]
[/tr]
[tr]
[td] 1163 [/td]
[td] 1575 [/td]
[td] N/A [/td]
[td] N/A [/td]
[td] N/A [/td]
[/tr]
[/table]
DIMENSIONS
[tr]
[td]3-dr [/td]
[/tr]
[tr]
[td] Exterior [/td]
[td] [/td]
[/tr]
[tr]
[td] 3975 [/td]
[/tr]
[tr]
[/tr]
[tr]
[td] 1787 [/td]
[/tr]
[tr]
[td] 1456 [/td]
[/tr]
[tr]
[td] 2489 [/td]
[/tr]
[tr]
[td] Interior [/td]
[td] [/td]
[/tr]
[tr]
[td] 991 [/td]
[/tr]
[tr]
[td] 1111 [/td]
[/tr]
[tr]
[td] 1350 [/td]
[/tr]
[tr]
[td] 953 [/td]
[/tr]
[tr]
[td] 823 [/td]
[/tr]
[tr]
[td] 1300 [/td]
[/tr]
[tr]
[td] [/td]
[/tr]
[tr]
[td] 276 [/td]
[/tr]
[tr]
[td] 290 [/td]
[/tr]
[tr]
[td] 960 [/td]
[/tr]
[tr]
[td] 974 [/td]
[/tr]
[tr]
[td] [/td]
[/tr]
[tr]
[td] Petrol [/td]
[td] 42 [/td]
[/tr]
[/table]
STEERING
[tr]
[td] System [/td]
[/tr]
[tr]
[td] Ratio [/td]
[td] 13.69:1 [/td]
[td] [/td]
[/tr]
[tr]
[td] 11.2 [/td]
[td] [/td]
[/tr]
[/table]
WHEELS AND BRAKES
[tr]
[td] [/td]
[td] Front [/td]
[td] Rear [/td]
[/tr]
[tr]
[td] Braking [/td]
[/tr]
[tr]
[td] 278 x 23 [/td]
[td] 253 x 10 [/td]
[/tr]
[tr]
[td] 54 [/td]
[td] 34 [/td]
[/tr]
[tr]
[td] Wheels [/td]
[/tr]
[tr]
[td] Tyres [/td]
[/tr]
[/table]
CHASSIS
[tr]
[td] Front [/td]
[td]Rear [/td]
[/tr]
[tr]
and damper [/td]
[/tr]
[tr]
[/tr]
[/table]
ENGINE DATA
[tr]
[td] [/td]
[td] [/td]
(182PS) [/td]
[/tr]
[tr]
[td] Type [/td]
[td] [/td]
[/tr]
[tr]
[td] cm3 [/td]
[td] 1596 [/td]
[/tr]
[tr]
[td] Bore [/td]
[td] mm [/td]
[td] 79.0 [/td]
[/tr]
[tr]
[td] Stroke [/td]
[td] mm [/td]
[td] 81.4 [/td]
[/tr]
[tr]
[td] [/td]
[td] 10.1:1 [/td]
[/tr]
[tr]
[td] PS (kW) [/td]
[/tr]
[tr]
[td] [/td]
[td] at rpm [/td]
[td] 5700 [/td]
[/tr]
[tr]
[td] Nm [/td]
[td] 240 [/td]
[/tr]
[tr]
[td] [/td]
[td] at rpm [/td]
[/tr]
[tr]
[td] [/td]
[td] DOHC
[/tr]
[tr]
[td] [/td]
[/tr]
[tr]
[td] [/td]
[/tr]
[tr]
[td] [/td]
[/tr]
[tr]
[td] [/td]
[/tr]
[tr]
[td] [/td]
[/tr]
[tr]
[td] [/td]
[td] Bosch [/td]
[/tr]
[tr]
[td] [/td]
[/tr]
[tr]
[td] [/td]
[/tr]
[tr]
[td] [/td]
[/tr]
[tr]
[td] [/td]
[/tr]
[tr]
[td] litres [/td]
[td] 4.1 [/td]
[/tr]
[tr]
[td] [/td]
[/tr]
[tr]
[td] litres [/td]
[td] 5.5 [/td]
[/tr]
[tr]
[td] [/td]
[/tr]
[tr]
[td] [/td]
[/tr]
[tr]
[td] [/td]
[td] [/td]
[tr]
[td] 6th 0.690
5th 0.821 [/td]
[/tr]
[tr]
[/tr]
[tr]
[/tr]
[tr]
[/tr]
[tr]
[/tr]
[tr]
[/tr]
[tr]
[/tr]
[/table][/td]
[/tr]
[/table]
