hy,
according that phenomen i already found suspicious things the switch are not working or the period the signal come through the button was not enough. anything like that, but even i know only european ST they are not that kind of a surprise and thesport mode always work in all of em.
Did you try that before the stage was made? Even i do not think that one is matter the other one, nobody knows ;-)
cheers, T
p.s.
just have seen you already wrote the factory tune had the sport mode. hm, ask cobb whatever they mean. anyway the sport mode CAN be already like i want it-alwasy there-or it is not because somebody at cobb means it is unusual??
T,
If I understand you correctly, you're suggesting either the ESC button's switch doesn't work at all, or the length of time the button is pressed is not enough time to engage the switch.
The ESC switch works to disable ESC, so I don't think the physical button/switch is the problem.
When I quickly press then depress the ESC button for about 1 second, nothing happens. When I press the button and hold for over a second, the video display indicates that I should continue to press/hold the button to disable ESC, and after a couple more seconds the ESC is disabled and the usual icon illuminates in the dash cluster.
Yes, to confirm, I did have a functioning sport mode before I loaded a Cobb OTS tune, but because I've hardly ever used sport mode, I can only confirm these are correlations without a clear causal link.
So I repeat, am I alone in this phenomenon?
Thanks
