COBB AccessTuner Race - New Update Release Announcements
BoostBumps
Arizona
FYI...
New update for ATR released today....
Details:
https://cobb.app.box.com/ford-tuner-release-notes
Nothing really major (FiST Related) other than some new monitors and a toggle or two...
[HR][/HR]
Tuner Update:
Accesstuner Pro: 1.9.1.0-10512 Accesstuner Race: 1.9.1.0-10512
Date:
6/11/15
Special Instructions:
Compatible Firmware:
AP-FOR-001: 1.6.8.1-8832 or greater.
AP3-FOR-001: 1.7.2.0-10512 or greater.
AP3-FOR-002: 1.7.2.0-10512 or greater.
AP3-FOR-003: 1.7.2.0-10512 or greater.
Compatible Maps:
Focus ST OTS Maps: v312 or greater
Fiesta ST OTS Maps: v201 or greater
Fusion EB OTS Maps: v110 or greater
Mustang EB OTS Maps: v120 or greater
Maps saved by Compatible Tuner 1.9.1.0-10512 or greater
New Features:
Added Custom Tuning Features for the Ford Fusion EcoBoost Models
Features available in updated tuning guide cover sheet:
5-Way Map Switching
Vehicle Applications:
SADM 2014 Fusion 2.0L AT (FWD)
USDM 2013-2014 Fusion 2.0 (AWD)
USDM 2013-2014 Fusion 2.0 (FWD)
USDM 2013 Fusion 1.6 AT
USDM 2013-2014 Fusion 1.6 MT
New Vehicle Support for SADM 2014 Fusion 2.0 FWD All Models:
New Monitors:
LTT Torque (Base)
LTT Torque (Loss)
LTT Torque (Final)
TTL Torque (Base)
TTL Torque (CLIP)
TTL Torque (Final)
Load Desired (TTL)
TR Ratio (LTT)
TR Ratio (TTL)
****2015 Models only TR Ratio (Spark) Requested Torque Mult. (OSS)
Improvements:
DTC Descriptions - DTC descriptions are now shown in the "Advanced Engine Parameters" dialog box.
Extended description (tool tips) - place mouse over DTC for extended description.
Expand DTC Names (check box) - The descriptions can be hidden by toggling the "Expanded DTC Names" check box in the bottom left hand corner.
Wideband Sensor Support:
Improved serial communications for AEM UEGO AFR. AEM UEGO protocol now supports the Autometer Wideband.
Added support for AEM Inline Wideband UEGO AFR Controller.
koozy
Los Angeles, CA, USA
Updated, thanks for the heads up. I found it interesting that for the Focus you can disable the sound symposer through ATR, but not the Fiesta yet....
BoostBumps
BoostBumps
Arizona
ATR Update Available: 1.9.1.0-10561
Tuner Update:
Accesstuner Pro: 1.9.1.0-10561
Accesstuner Race: 1.9.1.0-10561
Date:
6/24/15
2013-14 Focus ST: Updating Legacy (older revision) Maps:
- Existing Table structures have changed and careful review is required when updating existing ATR and ATP maps to the new format.
- Cruise Control button mappings to custom features has changed and affects access to custom features.
AP3-FOR-001: 1.7.2.0-10621 or greater.
AP3-FOR-002: 1.7.2.0-10621 or greater.
AP3-FOR-003: 1.7.2.0-10621 or greater.
Compatible Maps:
Maps saved by Compatible Tuner 1.9.1.0-10561 or greater
Improvements:
Improved Data Logging Throughput (V3 Devices only)
~100% increase in logging through-put for all Ford part numbers.
Improved ECU selection filters
- Addressed an issue causing empty lists to show in the "Please select an ECU type." drop down.
- Added "Reset" button.
[HR][/HR]
Comments:
Appears to be only minor changes made specific to active tuning ....
koozy
boo... no flex fuel goodies. [lovecobb] [hihi]
seriously [MENTION=555]COBB Tuning[/MENTION] it would be a great addition. Some of us would really appreciate the integration.
