Oil Catch Can Comparo Thread
Which OCC did you install?
  • Mishimoto
    Votes: 48 30.2%
  • Boomba
    Votes: 9 5.7%
  • James Barone Racing
    Votes: 3 1.9%
  • Damond Motorsports
    Votes: 71 44.7%
  • "Custom"
    Votes: 10 6.3%
  • Other
    Votes: 18 11.3%
  • Total voters
    159
BoostBumps
Arizona
Things that "I" would like to see from an OCC kit... So far none of the 3 check "all" the boxes yet...Although JBR's OCC Kit does come very close.....
- OCC with baffled internals
- 5/8" inlet and outlet ports
- Minimal hose routing lengths
- Easy draining capability
- Relatively stable & open mounting location
- Quick OE Hose Connects
- 5/8" check valve
- Greater than 120ml (4.0 oz) holding capacity (drain every ~5k miles)
MOFiST
Adelaide
That post is from 11 weeks ago and says the can should be available in June. I'm not holding my breath.
The can I currently use is salvaged from a Matt Damond kit for my Mazdaspeed. He's a good guy and well respected over in Mazda land. That position his kit uses doesn't suite RHD cars however.
tjd_tdi
Columbia
Thread Starter #23
Updated first post with new info on the Boomba cans.
tjd_tdi
Columbia
Thread Starter #25
FYI...
Doesn't appear "plug and play" for those looking for an easy install....
Yeah, they need you to actually cut the stock PCV or CCV hose. It may actually be (slightly) easier than the Barone kit, where you have to remove the fittings from the stock hoses. But, it looks like Mishimoto is the only true plug and play, where you don't lose your stock hoses...
BoostBumps
Arizona
I don't think its any easier than Barone's considering all the extra hose clamps needed and cutting of OE PCV tube in half...And it actually looks like far more work and effort to me...And quite a bit more hose length and routing required...
tjd_tdi
Columbia
Thread Starter #28
I don't think its any easier than Barone's considering all the extra hose clamps needed and cutting of OE PCV tube in half...looks like far more work and effort to me...And quite a bit more hose length and routing required...
Yeah, you could be right. I'll be interested to hear your impressions once you get your Barone kit and install it.
TheStig
Phoenix
Mishimoto is looking the best for me personally. 100% plug and play plus they have been totally transparent about everything and prompt with answers.
I like the other two offerings but the Mishi appears to be best for me.
NorCal
#31
I'm tempted to go JBR now since it's actually available and is the least expensive. Still mulling over it.
BoostBumps
Arizona
#33
The only negatives I see with the Mishimoto's is that its directly mounted on an engine mount which will vibrate like hell and hopefully the bracket won't snap or fail over time due to metal fatigue (I've seen this happen before with others mounted to engine mounts)....The can capacity is quite small so you'll be emptying the can far more often and cleaning that very dense 50 micron filter...And lastly the NPT connections are 3/8" with 1/2" nipples (OE PCV Line is 5/8")....
TheStig
Phoenix
#34
And I share the worry with the mounting location, everything else im not so worried about. If im cleaning the catch can with every oil change size isnt necessarily an issue.
BoostBumps
Arizona
#35
With the amount of residue I've seen with prior cans I've had installed on the FiST after only 1500 miles I'm thinking your going to be having to be empting that OCC far more frequently then at oil change intervals..But the location allows easy access to unscrew to dump out the residue...you never want an OCC can to fill up more than half way particularly if your not going to be installing a check valve between IM and OCC...
Just things to consider....
That said I think the Mishimoto's would probably be the best choice for most folks simply for ease of install....
tjd_tdi
Columbia
Thread Starter #36
After 1500 miles, I've seen very little accumulation myself--<1 ml per 100 miles. If you're changing oil every 5k, that's something less than 50ml. Even the small Mishi can has a capacity of 65ml.
BoostBumps
Arizona
#37
I've seen much more than that with my JLT OCC ...What OCC did you have installed?
And personally I don't like having my OCC's filled more than half way between empties....
tjd_tdi
Columbia
Thread Starter #38
That's with the Mishi Compact Baffled Can that's currently in their kit. I'm also running the CFM breather, which may affect things. Also, my car only has 2500 miles, which again, may affect accumulation.
As you say, the can is easy to empty. Probably the most annoying thing (especially for such a small can) is no indicator for level of accumulation, as you get in either the Barone or the Boomba cans.
