Well mine squeaks too- and a little binding- started pretty much after about 1000 miles. I live where it's very hot- mostly all of the time. I lubed the pivot points once and it last for a little while- maybe 3K miles, then returned even worse. I re-lubed every pivot point I could see under the dash (I missed one key pivot point initially) and it seems to be much better now. It still get a rubbing, like vibration after the car sits for a few hours the first time I push the clutch in, then it subsides. I wonder if it's the heat that causes the pivot points to dry up and cause the squeaking? Anyway for now I am considering it "normal" as the pedal operates fine and the car shifts fine.
