yeah...no need for heroics...ha!
Would be nice to see what this kit looks like tuned to 280hp / 280tq...
looking forward to seeing soon!
I will get more data but here is a little something
Datalog 13 is old ATP set up. 100% WGDC to 4800rpm tapper to 72% WGDC at 6000rpm Holds 70% WGDC to limiter
Quick Spool Logs
Datalog 31 is wastegate pressure 5% WGDC
Datalog 49 is newer partial pull 3rd gear (20psi @3550rpm)
Datalog 45 is newer partial pull 4th gear (20psi @3350rpm)
Datalog 32 is older full pull (slower spool) 100% WGDC to 3500rpm Taper to 60% at 4500 which holds to limiter (peak tq is skewed because of slight wheel spin)
This shows the big time response difference also the control of the boost. As where the ATP set up is pretty well maxed out at its 24psi peak. There is alot more room to grow and we will have more solid data soon.
