Sourskittle
#41
I've done it enough that its not too bad. Like everything, first time you do it, its bad. 2nd time is much better. 3rd time your wondering why you had such an issue the first time, lol.
If someone would have offered last Dec, I would have pay'd them $150.
The turbo really isn't even that bad...
JPGC
#42
Getting the 2JR downpipe back in was easy. My main issue was the O2 sensor. I can't believe how tight it was. Especially in such a cramped area.
Sourskittle
#43
The O2 sensor and getting to all the heat shield bolts. I came ill prepared the first go around. 2nd time, I brought tools home from work, lol
JPGC
#44
Lol, I had to ride my bike during this 7 miles to get a tool. The wife was at work, so the bike it was. I know what you mean by "I'll prepared"
#45
Went the cp-e way.. just because I loved the brand with my ex MS3...
The difference between the stock and the cp-e QKspl is visible!
Loved the way it performs!!! The only con, is the quick heatsoak by my OEM IC =(
JPGC
#46
Nice downpipe. I wish the 2JR retained the mounting bracket like that, but for the price of the 2JR compared to others, I can't complain. Has anyone here who have replaced their stock downpipe with a "no bracket" downpipe had any issues due to no mounting bracket?
TheStig
#47
How is the downpipe causing your intercooler to heatsoak quicker?
#48
Not just the downpipe... But the accesport is making my turbo run at higher psi... So...
#49
Lol you're running the same boost as stock it just comes on fully instead of having to rev to 4k for full boost
iso100
#50
This is true. Even Stage 2 is maybe 1.5psi more than stock and Stage 3 is maybe 2 to 2.5psi more.
I think I might go with the CP-E downpipe though. They're local to me so I could just buy it and have them do the install as well.
I'm seriously thinking about trying this Ultimate Racing downpipe though. It has a 3.5" elbow instead of 3" and I'd be saving $100.
http://www.ultimate-racing.com/Products2/Fiesta_ST_14/Fiesta_ST_14_Downpipe.shtml
#51
whats the cel your getting after changind the stock dp.. and could it be possible to relocate the o2 sensor further down on the line to avoid getting any cel..
i had 2 cat on my truck, i gutted the one on on the manifold and then relocated that o2 sensor after the second cat and bingo no cel..
could this work??
Sekred
#53
That larger elbow will do nothing with the stock turbo. The turbine is the size of a dollar coin.
Its probably not going to make any difference between a 3 or 3.5 inch elbow but the down pipe itself is well worth doing.
Big turbo, small turbo the theory to make more HP is the same.
The following excerpts are from Jay Kavanaugh, a turbosystems engineer at Garret Engine Boosting Systems.
This thread (note, not this thread) was brought to my attention by a friend of mine in hopes of shedding some light on the issue of exhaust size selection for turbocharged vehicles. Most of the facts have been covered already. FWIW I'm an turbocharger development engineer for Garrett Engine Boosting Systems.
N/A cars: As most of you know, the design of turbo exhaust systems runs counter to exhaust design for n/a vehicles. N/A cars utilize exhaust velocity (not backpressure) in the collector to aid in scavenging other cylinders during the blowdown process. It just so happens that to get the appropriate velocity, you have to squeeze down the diameter of the discharge of the collector (aka the exhaust), which also induces backpressure. The backpressure is an undesirable byproduct of the desire to have a certain degree of exhaust velocity. Go too big, and you lose velocity and its associated beneficial scavenging effect. Too small and the backpressure skyrockets, more than offsetting any gain made by scavenging. There is a happy medium here.
For turbo cars, you throw all that out the window. You want the exhaust velocity to be high upstream of the turbine (i.e. in the header). You'll notice that primaries of turbo headers are smaller diameter than those of an n/a car of two-thirds the horsepower. The idea is to get the exhaust velocity up quickly, to get the turbo spooling as early as possible. Here, getting the boost up early is a much more effective way to torque than playing with tuned primary lengths and scavenging. The scavenging effects are small compared to what you'd get if you just got boost sooner instead. You have a turbo; you want boost. Just don't go so small on the header's primary diameter that you choke off the high end.
Downstream of the turbine (aka the turboback exhaust), you want the least backpressure possible. No ifs, ands, or buts. Stick a Hoover on the tailpipe if you can. The general rule of "larger is better" (to the point of diminishing returns) of turboback exhausts is valid. Here, the idea is to minimize the pressure downstream of the turbine in order to make the most effective use of the pressure that is being generated upstream of the turbine. Remember, a turbine operates via a pressure ratio. For a given turbine inlet pressure, you will get the highest pressure ratio across the turbine when you have the lowest possible discharge pressure. This means the turbine is able to do the most amount of work possible (i.e. drive the compressor and make boost) with the available inlet pressure.
Again, less pressure downstream of the turbine is goodness. This approach minimizes the time-to-boost (maximizes boost response) and will improve engine VE throughout the rev range.
As for 2.5" vs. 3.0", the "best" turboback exhaust depends on the amount of flow, or horsepower. At 250 hp, 2.5" is fine. Going to 3" at this power level won't get you much, if anything, other than a louder exhaust note. 300 hp and you're definitely suboptimal with 2.5". For 400-450 hp, even 3" is on the small side.”
"As for the geometry of the exhaust at the turbine discharge, the most optimal configuration would be a gradual increase in diameter from the turbine's exducer to the desired exhaust diameter-- via a straight conical diffuser of 7-12? included angle (to minimize flow separation and skin friction losses) mounted right at the turbine discharge. Many turbochargers found in diesels have this diffuser section cast right into the turbine housing. A hyperbolic increase in diameter (like a trumpet snorkus) is theoretically ideal but I've never seen one in use (and doubt it would be measurably superior to a straight diffuser). The wastegate flow would be via a completely divorced (separated from the main turbine discharge flow) dumptube. Due the realities of packaging, cost, and emissions compliance this config is rarely possible on street cars. You will, however, see this type of layout on dedicated race vehicles.
A large "bellmouth" config which combines the turbine discharge and wastegate flow (without a divider between the two) is certainly better than the compromised stock routing, but not as effective as the above.
If an integrated exhaust (non-divorced wastegate flow) is required, keep the wastegate flow separate from the main turbine discharge flow for ~12-18" before reintroducing it. This will minimize the impact on turbine efficiency-- the introduction of the wastegate flow disrupts the flow field of the main turbine discharge flow.
Necking the exhaust down to a suboptimal diameter is never a good idea, but if it is necessary, doing it further downstream is better than doing it close to the turbine discharge since it will minimize the exhaust's contribution to backpressure. Better yet: don't neck down the exhaust at all.
Also, the temperature of the exhaust coming out of a cat is higher than the inlet temperature, due to the exothermic oxidation of unburned hydrocarbons in the cat. So the total heat loss (and density increase) of the gases as it travels down the exhaust is not as prominent as it seems.
Another thing to keep in mind is that cylinder scavenging takes place where the flows from separate cylinders merge (i.e. in the collector). There is no such thing as cylinder scavenging downstream of the turbine, and hence, no reason to desire high exhaust velocity here. You will only introduce unwanted backpressure.
Other things you can do (in addition to choosing an appropriate diameter) to minimize exhaust backpressure in a turboback exhaust are: avoid crush-bent tubes (use mandrel bends); avoid tight-radius turns (keep it as straight as possible); avoid step changes in diameter; avoid "cheated" radii (cuts that are non-perpendicular); use a high flow cat; use a straight-thru perforated core muffler... etc.”
"Comparing the two bellmouth designs, I've never seen either one so I can only speculate. But based on your description, and assuming neither of them have a divider wall/tongue between the turbine discharge and wg dump, I'd venture that you'd be hard pressed to measure a difference between the two. The more gradual taper intuitively appears more desirable, but it's likely that it's beyond the point of diminishing returns. Either one sounds like it will improve the wastegate's discharge coefficient over the stock config, which will constitute the single biggest difference. This will allow more control over boost creep. Neither is as optimal as the divorced wastegate flow arrangement, however.
There's more to it, though-- if a larger bellmouth is excessively large right at the turbine discharge (a large step diameter increase), there will be an unrecoverable dump loss that will contribute to backpressure. This is why a gradual increase in diameter, like the conical diffuser mentioned earlier, is desirable at the turbine discharge.
As for primary lengths on turbo headers, it is advantageous to use equal-length primaries to time the arrival of the pulses at the turbine equally and to keep cylinder reversion balanced across all cylinders. This will improve boost response and the engine's VE. Equal-length is often difficult to achieve due to tight packaging, fabrication difficulty, and the desire to have runners of the shortest possible length.”
"Here's a worked example (simplified) of how larger exhausts help turbo cars:
Say you have a turbo operating at a turbine pressure ratio (aka expansion ratio) of 1.8:1. You have a small turboback exhaust that contributes, say, 10 psig backpressure at the turbine discharge at redline. The total backpressure seen by the engine (upstream of the turbine) in this case is:
(14.5 +10)*1.8 = 44.1 psia = 29.6 psig total backpressure
so here, the turbine contributed 19.6 psig of backpressure to the total.
Now you slap on a proper low-backpressure, big turboback exhaust. Same turbo, same boost, etc. You measure 3 psig backpressure at the turbine discharge. In this case the engine sees just 17 psig total backpressure! And the turbine's contribution to the total backpressure is reduced to 14 psig (note: this is 5.6 psig lower than its contribution in the "small turboback" case).
So in the end, the engine saw a reduction in backpressure of 12.6 psig when you swapped turbobacks in this example. This reduction in backpressure is where all the engine's VE gains come from.
This is why larger exhausts make such big gains on nearly all stock turbo cars-- the turbine compounds the downstream backpressure via its expansion ratio. This is also why bigger turbos make more power at a given boost level-- they improve engine VE by operating at lower turbine expansion ratios for a given boost level.
As you can see, the backpressure penalty of running a too-small exhaust (like 2.5" for 350 hp) will vary depending on the match. At a given power level, a smaller turbo will generally be operating at a higher turbine pressure ratio and so will actually make the engine more sensitive to the backpressure downstream of the turbine than a larger turbine/turbo would.
#54
Hello,
I'm looking to bought the downpipe from Cobb or Mountune when it will be released.
What is the advantage of the downpipe from Cobb? (More power, Best turbo response)
if I just install the downpipe from Cobb or Mountune with the stock exhaust did I see a real difference or I need other modification before buy a downpipe (Intake or bigger intercooler)?
Sekred
#55
I doubt there would be any difference between the Cobb and Mountune downpipes power wise. I think both are 3 inch and neck down to 2.5 at the outlet.
If you are changing the downpipe, do the exhaust as well, its the reduction in back pressure that gives the power increase and faster spool.
The intercooler, that's up to you. The OEM intercooler is very average and heats soaks quickly, cooler charge temps will give you more power.
Get a tune to take maximum advantages of the changes you make.
iso100
#56
I have a 3" mbrp on the way and eventually will do the Cp-E downpipe.
#57
I Probably don't change my exhaust if a buy a downpipe because I like the sound of the OEM exhaust and for the moment I don't need more sound!
Is it a good buy (Downpipe) if I keep the stock exhaust?
Thanks.
razorlab
#58
I was talking about the elbow size, nothing about upgrading the exhaust or not. Next time you see Jay, tell him I said hi.
Thanks for the copy paste of a post that has been all over the internet for at least five years though. ;)
iso100
#59
I think what they're going for with the 3.5" elbow is to keep the diameter as large as the turbo outlet at least until the bend is complete. Even a 3" elbow mated to the flange has to neck down and it would do so abruptly. I'm thinking delaying the reduction in size until after the bend will keep the Flow Gods™ happier.
razorlab
#60
I think the stock turbo is more like a flow pixie, not a god. ;)
