Ok big update. A lot of things learned...
Started at 9:30 with my friend helping me. 30 minutes in we got the first one open, many fist bumps and morale was super high since we expected this to be the hardest part of the retrofit (it's not). 20 minutes later we had the other one open.
Next we took the reflectors off, whoops broke one of the mounts to the ball joints, specifically one going to the adjustment knob. JB Weld to the rescue. Be careful removing the reflectors...
We sanded the back of the reflectors flat and opened up the light bulb hole to accept the mini h1s.
Next we painted the reflectors and shrouds flat black, then it was lunch time.
After lunch we ran the harness and connected it to the battery and ground and mounted the ballasts to the crash beams. There was a hole I used to mount the relays as well. Pictures below.
The passenger side feed wire simply goes under the plastic piece on top of the bumper. Two screw push pins hold it closest to the engine bay, simply remove them and carefully pull it up enough to pass the harness over. Easy peasy.
It's 1:30 and we're getting started on removing the permaseal. We won't finish this task until around 5 pm. This is why retrofitters charge cash money on certain jobs. Removing this stuff is pulling gum out of shag carpet, only it's not gum it's construction adhesive. It doesn't respond much to heat but it helps. Sharp blades kind of just get stuck or don't really cut it. It's hell.
Well after that was all done we test fitted the drivers side, fired it up, and amazingly the height was almost spot on. The beam was at a 45 degree angle haha but we fixed that. Passenger side was straight and height was good. We had an annoying situation with a striker not firing but switching sides made them work. We did not like that game at 10pm.
Tomorrow we run through the final steps of checking and rechecking everything, cleaning the reflectors, and baking them up with fresh butyl.
I'm tired, my fingers hurt really bad, but I have proper HIDs in my Fiesta.
Sorry about the book of a comment...
