Broke bolt heads while installing RMM
Hello,
After installing my cpe RMM I over torqued two bolts and snapped the heads off, Now i need to get those bolts out and replaced, I purchased a bolt extraction kit but given that these bolts go into the engine block i am hesitant. any advice? What would dealership charge for this?
Hello,
U should just be able to get those out without an extraction kit, under the downpipe bracket there are 13mm hex heads that you can use unless I'm missing something.
Sent from my SM-N975U using Tapatalk
Rocketst
I actually think I see the nut behind the bracket in his picture...
thedraque
That worked thank you, got the bolts off no problem. REALLY glad I posted before i started drilling
Now find the Torque specs. HE-Man. Go to ferd and order new bolts.
According to the manual the bolts holding in the RMM itself should be torqued down to 50 Nm and the nuts holding the bracket only need to be torqued to 24 Nm.
That's 50nm= 36 Ft. Lbs and 24nm to 17 Ft lbs for any of you meatballs out there that no have no converty skillys.
I thought I saw 70Nm, for the bolts, in the manual.
DEss
DEss
You may be right, I think I only found instructions that show the torque for the rmm bolt on the subframe side.
MagnetiseST
I mean... you don't really need the front part of those bolts unless you are dying to run the dp support bracket.
MagnetiseST
If you deleted that bracket couldn't it cause your knock sensors to read falsely though? Pretty sure my exhaust contacting the vehicle when I first installed it was contributing to my knock.
The exhaust shouldn't touch a thing even with that bracket off. I do not have mine on, and have never had false knock.
You should be fine while u wait for replacement bolts, might have a bit of rattle from the exhaust but it shouldn't be too big of an issue
The instructions that come with the CP-E RMM clearly state to use 52 LB. FT. right in the text. [wink]
I don't know if that differs from the Ford manual or not. [dunno]
Now that you mention it my Vibratechnics RMM stated 67nm which translates to 50 Ft. Lbs.[rockon]
JDG
Since everyone is chiming in, I will too. All the rear motor mount bolts are 51.6294 Ft-Lbs. The downpipe bracket NUTS are 17.70 Ft-Lbs.
Thanks, what section is that in I don't know why I couldn't find it in my manual.
pixelzombie
Hello,
Are you a power lifter? It seems you'd have to use a lot of force to snap the head off such a bolt.
Maybe a 6 foot long extension on a ratchet! Gotta get that leverage!
