- Member ID
- #6412
- Messages
- 143
- Likes
- 45
Finally got these installed, first set in the USA with 2-piece rotors that fit without spacers, for my wheels at least. They clear the OZ Ultraleggera 17x7 ET42's with no problem and may also clear the OEM wheels but I dont have them to test fit. Didnt run into any snafus besides the instructions listing the bolts going into the brackets backwards and we had to bleed from both caliper screws to get all the air out. Taking it easy on them for 300 miles per the instructions, but so far the pedal feel is massively improved. Stiffer and more linear with a lot of initial bite, very streetable in traffic. A quick stop from 25-30ish about pulled the rear wheels off the ground, suffice to say, they work! I do have about 135lbs out of the back and lightweight rims though. We didn't need to use any shims as the rotor was well centered when we fit it, so that was a plus. Pad coverage on the rotor looks excellent. Can't wait to get some miles on these and see what they can do. Excellent customer service from Paul McGrath at Tarox USA, dont hesitate to reach out to him. Price was $2200 USD for the kit. Shipping is from Italy so expect to be patient for these, but Paul helped track them throughout! I weighed all the components myself to give exact weights below.
I attached the template as well for checking wheel clearance that Tarox provided if anyone is interested in the kit.
Part #: KMFO1141T (the T indicates the two piece set, KMFO1141 is the one piece rotor version of the same kit fyi)
Link: http://www.tarox.co.uk/product/tarox-brake-kit-ford-fiesta-mk6-st180-sport-kmfo1141t/
Specs:
Kit received (doesnt show the brackets):
Before:
Before:
After:
After:
Specs:
- 6 Piston Billet Calipers (7 lbs each, vs 11.4 stock lbs each), hard anodized in Gold color
- 300mm Two-Piece Rotors w/Billet Hats (13.8 lbs each, vs 15 stock lbs each), pre-assembled and torqued from Tarox
- PTFE Lined Stainless Brake Lines w/PVC Outer Coating
- Billet Aluminum Mounting Brackets
- Bolts and Accessories w/Shims
Before:
Before:
After:
After:
![Big Grin [biggrin] [biggrin]](/images/smilies/biggrin.gif)
