Colorado
Haha. Good eyes. I had a flat on one of my gravel tires before tech, and stupidly only brought one snow tire spare. Ended up with stock rears. They are some pretty old cooper rally tires I got from a local rallycrosser. The pilot sport rears were nice and slidey. Maybe that made for easier initiation and oversteer. I don’t have a great gauge yet though this was my first Motorsport race. The car was very predictable and I could throttle out of a turn easily.
AthenaAutocross
U.S. Navy Veteran
Washington
Believe I've found my oil problem. When I replaced the PCV hose I noticed I was getting some blue/white smoke, I thought I blew out a seal or something. I put the catch can in and it went away but the can wasn't the best for my power and I ended up removing it and just doing a straight hose with the UPR 100 psi check valve, and that seemed to work great but I started getting weird blue/white smoke and couldn't figure it out. Opened up the intercooler cold/hot sides and no oil there. Bought that endoscope and checked a few spots initially and saw some oil on the back under the valve cover gasket and thought I blew it out so I replaced that. Was still getting smoke under the hood and small buffs out the back and started to really worry I blew my hotside seals.
Well last night after a drive to warm up the car for fresh leaks I pulled the scope out and started looking for other oil spots. Well, I saw a big blob of oil on the backside of the block (Lower images) and could not figure out where it would come from, then as I was scanning the video I saw I'm missing a stud/nut for the manifold to turbo..
Which means my oil issue is I'm picking up and burning a butt load of oil through the PCV without the catch can installed (I checked the hose and it has so much oil in it) and I only didn't notice it for so long as my OEM PCV pipe had a tiny crack in it and was bleeding the oil into my engine bay ever so slowly as a vacuum leak. When I fixed that I happened to have a stud fallout of my turbo which caused the unburnt oil to spill onto the back of the block and slowly burn off, and what ever didn't get there was getting into my turbo and downpipe and slowly burning off there which would explain the absolutely random way the smoke would come out the backside under no set condition.
Answer, put a catch can back in and fix this darn stud.
Houston, TX
Melted out the old ball stud and added a threaded rod n bolt with a new extended ball studs on top. The clamping force holds it in good but imma add some epoxy as well. Hoping this works out if not I'll just have to reduce the length of the extension a bit. I got the idea from Reddit
AthenaAutocross
U.S. Navy Veteran
Washington
Photographer posted some of the pictures from the last event. Here are some of the cars I'm up against, on blown out 91k mile factory 16' suspension I'm less than 1 second behind these cars in my class on a 44 second course.
LS1 swapped FRS on 300mm tires, Mazdaspeed6 swapped Miata on 300mm tires and several supercharged, turbo Miatas.
Pretty happy with being within 1 second of these guys on 205s, no suspension mods and no aero. (I actually reviewed the videos and I kept up until the high speed corner in the back where I lost .5+ seconds from not going all out)
If I can get that time back with the coilovers and some wider tires I'll be top 10 raw times.
Houston, TX
Happy to say the shift ball extension works! Shift throw is much reduced and a lot notchier! Feels so much better and shorter. Also wired up my recaro seats so they are heated now 😀
It looks janky asf especially since I had to melt the old ball out but it's solid and works. I've been shifting hard and it's been fine
AZ
Installed the DNA rear sway/torsion bar. Install was 15 minutes.
So far after just a little driving around town, i can tell the rear of the car seems more stable.
Im glad it only took a short time to install...i started at 6 am and it was hot as balls by the time i was done.
Grsemky
U.S. Navy Veteran
Arizona
What year is your fiesta? I have an '18 with the stiffer rear beam, I've been wondering if it would be worth it for mine...
