*New Product* Fiesta ST Pumaspeed Racing Fiesta ST180 Lightweight Uprated Pulley
Trader history for pwnall1337 (0)
pwnall1337
Vendor
San Antonio
Pumaspeed Racing ST180 Billet Uprated Pulley - Pumaspeed Billet CNC
Precision CNC machined
12.5% reduction in drag
Sharper throttle response
Less rotating mass
Various anodized colour choices
The new Pumaspeed Racing pulley is the first in a new line of race spec products designed to increase performance for Your Fiesta ST 1.6 Ecoboost.Perfect for road going race cars or daily drivers, driven fast.
This CNC machined pulley is made from Aircraft Grade Billet 6061 Aluminium and reduces excessive engine load from ancillaries. It gives a sharper throttle response and has less rotating inertia than stock (485 grams vs 256 grams). The pulley is bigger than stock, which means the ancillaries are driven slightly slower to reduce parasitic losses,allowing for more horsepower getting to the wheels and not being wasted through the water pump.
These are anodized for wear resistance and look incredible.
Replacement slightly longer pulley belt recommended and available in options.
47% Lighter than OEM!
http://pwnallperformance.com/Fiesta...a-ST180-Lightweight-Uprated-Pulley_p_130.html
jeff
Evans
And there is no ill effect on alternator output / coolant temperature?
I monitored everything very closely for a full month after install. Temps stayed right around where they were with the OEM pulley, no really measureable difference, all electrical systems working just fine.
My little car kept up with a Hellcat at full throttle the other day from 10-60 mph, I have to believe that little mods like this help make the difference. The car is fast.
