So yesterday out of nowhere I noticed a slight hesitation on full load when revs were between 2500/3000 revs. Ran codes on forscan with no sign of anything unusual. Went for a drive logging data such as timing and maf sensor. The blips are shown clearly on the red line below. Today I took it out and the stutter has developed into a huge misfire sounding like 3 cylinders. Nursed it home and removed the plugs. Removing the coil packs individually I could hear a noticeable change in engine tone across all 4 cylinders. However further inspection shows Cylinder 3 has a failed spark plug shown below and the earth electrode is no where to be found. I am hoping a bore scope and a magnet will find the missing piece and that it dropped whilst taking the plug out. Worst case scenario it has been flung throw the turbo or up into a valve. These plugs were changed when I bought the car just under a year ago. I have never come across a failure like this and I am trying to figure out what would possibly cause it. Cylinder 1,2 and 4 are perfect. I have always monitored data on the torque app , boost intake temps and coolant temps showed no change leading up to this failure so it has me stumped. If anyone has experienced anything similar, any advice would be greatly appreciated
