Molten Orange touch up paint
Missouri
Ok what I'm reaching out for is a brand / link of touch up paint that matches Molten Orange. I went with Motorcraft on my hot pepper red Focus and the paint match was awful. So I don't want to make the same mistake again (I've had bad luck on other cars as well) with Motorcraft. Before I waste $30 on a paint pen that's not even close to molten orange thought I'd ask someone whose done it.
BC, Canada
FWIW, I have performance blue, but I've recently had good experience with https://scratcheshappen.com/. Their paints are water based and I found it much easier to work with than the Ford pen. Colour match was pretty close too, although it came out a little bit darker if you're looking at just the wrong angle. The downside is you can't really sand base coat so you have to be pretty precise with the brushes to not overpaint (but if you do you can just wipe it away fairly easily and retry)
J
Missouri
Thanks that's what I'll go with. With these metallic colors, especially orange or silver seems the Motorcraft just does not match at all......and I have read that on some other posts as well. On my orangish/reddish focus the color was not even close, way darker.
