Selling my 2015 Fiesta ST (ST1), clean CA title, 65,048 miles. Located in Van Nuys, CA. Asking $10,000. It's been maintained the way we all wish the previous owner had done it. Full documentation with part numbers. Due to my current circumstances I can't keep it, and I'd prefer it stays out here on the lovely west coast with someone who'll appreciate it.
Service history (all completed):
Mechanically the car is sorted, but there's some cosmetic wear:
- Timing belt job: BE8Z-6268-C belt, BM5Z-6K254-A tensioner, 7S7Z-8501-C water pump + BE8Z-8507-A gasket, crank pulley bolt, valve cover gasket (BM5Z-6584-B)
- Transmission flush (BG Syncro) with GREDDY Transmission oil plug , clutch fluid flush, brake fluid (Motorcraft DOT 4)
- Oil + filter (5W-20), air filter, cabin filter, Motorcraft iridium plugs
- OEM motor mount kit
- Coolant, radiator fluid, misc hardware/bolts refreshed
- BC Racing BR Series coilovers
- StopTech brakes + rotors (4-wheel)
- StopTech stainless steel brake lines
- Whiteline adjustable sway bar links
- Grid 2 17" by ROTA (4x108) on Bridgestone Potenza Sport 215/40/17
- Alignment
- Sync 3 head unit swap (Sync 2 → Sync 3 w/ adapter) — CarPlay/Android Auto
- Whoosh short shifter
- Window tint
- OEM cargo cover reinstalled
- Side molding retainer clip refreshed
- Car obtained: 59,278 mi
- Cabin & oil filter, oil change, tire rotation: 59,398 mi
- New tires & rims: 7/5/25
- Spark plugs replaced: 60,002 mi
- Front & rear brakes/rotors, brake lines, brake fluid flush, transmission fluid flush, short shifter installed: 62,020 mi
- Timing belt & water pump: 62,375 mi
- Current mileage: 65,048 mi
- Front bumper has a sizable crack (previous owner)
- Side skirt has some scratches
- Curb rash on the Grid 2s
- Rest is mostly minor exterior cosmetic stuff
