stumbling/sputtering under heavy throttle
Richmond
Hi all! I bought a FiST yesterday. It's a salvage/rebuilt. On the drive home I went to pass on the highway WOT in 4th and it stumbled bad. I tried again in 2nd after taking an exit and again it fell on its face. It seems any throttle input greater than 50% causes this. Otherwise it drives fine.
Mods disclosed were Cobb RMM and whoosh sound symposer delete. Also the seller installed a stock muffler as it came with aftermarket. When the weather gets better I will be looking it over more thoroughly.
Things I'm considering :
Bad gas from sketch station
Plugs/coils
Original owner tuned and did not return to stock(seller did not tune and is not aware of any tune)
Bad catalytic converter?
Exhaust leak? Would effect be this bad??
Bad air or fuel sensor
Some other unknown mod yet to be found
No CEL and I've checked for stored and pending codes using a Bluetooth reader + torque
If the car is tuned how does that work? I'm going to get an accessport (wtb thread coming soon) but will it be able to overwrite the tune that is possibly on the ecu already?
Sent from my Nexus 6 using Tapatalk
I'm leaning towards a fuel related issue from what you have said just now..... no codes... do you have an AP3 to check Air fuel ratio? To see if it runs lean under throttle? IF YOU SEE IT START TO LEAN OUT DO NOT GET INTO THE THROTTLE AS IT CAN DETONATE! This is not good .....Motor go boom if it happens. Until it can be verified id stay out of boost.[nono]
Richmond
I've sent an email to Cobb support asking if a new accessport would marry and function on an already tuned car
Do you have the stock tune still?
Richmond
I have no idea what tune is on the car. I'm working with limited knowledge based on what the seller told me about it. It's like a really expensive but fun puzzle [emoji16]
kivnul
U.S. Army Veteran
Deer Park, WA
With the car running and cruise control turned off, hit the cruise control cancel/resume button. If your tac needle moves to exactly 1k (or 2k or 3k etc) regardless of throttle input then you currently have a Cobb style tune. Hit the cancel/resume button again to go back to normal. If it does nothing then you do not have a Cobb style tune loaded. (but you may still have a diablo or other style tune loaded)
Richmond
With the car running and cruise control turned off, hit the cruise control off button. If your tac needle moves to exactly 1k (or 2k or 3k etc) regardless of throttle input then you currently have a Cobb style tune. Hit the off button again to resume normal. If it does nothing then you do not have a Cobb style tune loaded. (but you may still have a diablo or other style tune loaded)
Thanks! It definitely does not have a Cobb tune. I did some more inspecting and am curious how the stock vacuum lines are ran. Is there a diagram somewhere? One of the lines going that is connected to the intercooler pipe is crimped Here are a couple of pictures from mine.
kivnul
U.S. Army Veteran
Deer Park, WA
I need to amend my instructions as they were in error. Instead of the Off button you need to use the cancel/resume button. I apologize.
Lawrence
View attachment 18047 View attachment 18048 View attachment 18049
In your first pic, what line is that with the kink in it?
felopr
JD
Need a more pan out shot to make where that hose is from
apart from being dirty , everything looks ok, also you have a aftermarket cold side charge pipe. more photos of it.
Also check the air filter
Richmond
Thread Starter #14
Willing to bet it's the coils/plug gaps.
Sent from my SAMSUNG-SM-N910A using Tapatalk
Coils look good. Plugs were .031 .030 .031 .030
Pic
Air filter looks good too. I should have included in my original post that the car only has 18K miles.
Richmond
Thread Starter #15
AP is on the way. Does anyone have any thoughts on how those plugs look and if they should be gapped closer? I'm thinking about putting a new set in just to rule it out
Richmond
Thread Starter #17
plugs look ok to me.
maybe a little rich but hard to tell
they are gap correctly
Thanks. Any thoughts on the kinked line? I've been looking on tasca and I think it may be part of the evap system? Trying to find a part number for it. Would it being kinked cause the symptoms I'm seeing?
felopr
JD
yes is part of the evap fuel lines
i would like to take a better look at the kink to see and where in the line is that kink to see if it is ok
would it cause the symptoms? no, dont think so imo.
Richmond
Thread Starter #19
It's about midway in the line, right next to the airbox
