Fiesta Flash Tune V2 Updates!!!
I have been working very hard over the last few months to get an updated Flash Tune released for you Fiesta guys. My main concern was to address the part-throttle surging that some of my customers have experienced. I have also made refinements to timing control strategy, load/torque targeting and a slew of other things. I also figured if I was going to release another version, I might as well offer you guys more features! And like all other features/options offered by Dizzy Tuning, they are no charge to add, edit or remove.
Current options:
Desired Idle RPM – Perfect for eliminating NVH, caused by aftermarket engine mounts
Desired LC Setting – Launch Control Setting for race use
Desired FFS setting – Flat Foot Shift setting for race use
Shift Assist (rev hang) On/Off – with custom settings for smooth shifts
Upshift Indicator Light On/Off – get rid of that pesky arrow light in the dash
Free datalog review is still included
V2 options being added:
Economy slot added – lower boost, fueling and timing changes for fuel economy, with map switching on the fly
Additional Anti-theft map – A temporary map that can be flashed to your vehicle, rendering it immobile
Automatic Traction Control On/Off – No need to turn it on every key cycle
Automatic Traction Control Mode Selection – No need to select this every key cycle
The Flash Tune will still be priced at $75, and you will get all the above options, at no additional charge!
Keep a look out for this being released by the end of the month!
Current options:
