Did you guys know that some oil companies like Pennzoil, Valvoline and Quaker State offer free engine warranties? Some out to 500,000 miles just by using their oil. They almost never have claims because if you change your oil and filters your engine will not fail due to lubrication. But if you want free insurance it is available. You are going to change your oil anyway right? My 1981 320iS BMW did over 330K and burned no oil. And this was Quaker State dino oil!
Quaker State covers the following
Pistons & Piston Rings
Oil Pump & Timing Chains
Crankshaft and Bearings
Rocker Arms and Pivots
Rods
Rod Bearings
Push Rods
Camshaft and Bearings
Valve Stems and Guides
Wrist Pins and Bushings
Turbo Bearings
Valve Lifter
Cylinder Lining or Bore
Distributor Drive Gear
Timing Gears or Sprocket
They also give you $3000 back if you go 300,000 miles in 10 years.
Anyway, these programs are free and some are transferable. Check them out.....free is like really cheap.
Rods
Rod Bearings
Push Rods
Turbo Bearings
Valve Lifter
