MCA Coilovers
Brisbane
Posted this on another forum but wanted to make sure the love was spread around thoroughly.
This week I went in for what was meant to be a final build and fit for my X-R series MCA Coilovers.
For those of you who don't know them, these guys bring decades of experience from rally, track and drift as both competitors and manufacturers. Murray Coote former Rally Champ handed over the reigns to his son Josh who teamed up with Luke Page manufacturing high quality suspension components for a wide range of applications.
While fitting up the rear suspension they decided that with the separate coil and shock arrangement was problematic, especially given the bend subjected to the coil springs in the torsion beam set up. As such they have designed a proper coilover for the rear with a slightly offset top plate to give it the clearance it needs. They will also have to shave down a small amount of the guard lining.
Sent from my D5833 using Tapatalk
Hijinx
U.S. Air Force Veteran
Auburn, AL, USA
Damnit. I just bought Meister Rs.
What is the planned adjustability for these (rebound only, rebound and compression separately adjustable {PREFERRED!}, rebound and compression together like everyone else does {and I refuse to buy!}, or 3 ways or something else)?
Would this fitment ever be offered in your Red Series, and if so, could separate rebound and compression adjustability be done as an option??
B
Brisbane
Thread Starter #13
To be clear, it's not "mine" per se, rather MCA are building them on my behalf. My build will be X-R series which has "Red" valving in terms of sophistication but they will set up for a "specific application" IE. Race, drift or comfort. Whereas Red series are custom made to your requirements. As such I expect you may be request separate controls for rebound and compression.
Dallas
Think I'm going to reach out about the "comfort" option?!? Bet those bad boys would cost a fortune to ship to the states?!?
B
Brisbane
Thread Starter #15
Ok in a monotube design apparently separate bump and rebound control is technically very difficult to provide without a remote reservoir (which is why no one does it). They are in the process of designing one however it's at least 12 months away at this stage.
With that said I'm confident that what they are providing me will work very well.
THANK YOU for that info! [thumb]
I can easily wait that long, since I do not even have the car yet, and want to drive it factory stock anyway to get used to it's dynamics before throwing major suspension mods at it.
(I'm coming from a much lower sitting, powerful NA LS1 V-8, shifter right into the internal rail of the gearbox, solid axle/rear drive coupe, it could not be much more different a driving 'feel' from a FiST, so I have A LOT to get used to with this car!)
I also have no problem (maybe not even the added expense) with a remote, or separate but attached to the damper body, reservoir if that's what it takes for independent adjustments. [wink]
B
Brisbane
Thread Starter #17
Rear top plates are ready. Fitting this Thursday.
Pete
San Diego
Any possibility they can make top hats alone to sell for adding unto other coil overs that don't provide them. Bilstein, vogtlands, kw, are a few brands of coil overs that reuse the oem ones. So finding a replacement would be awesome.
LilPartyBox
NYC
My knee jerk reaction assumes a damper acting directly on the spring is better. But... There was a theory thrown out when MRs first hit our forum that wondered if a spring over damper setup for the rear would present too much force to the upper mounting area. Possibly causing failure of the lil econobox stampings as time passed.
I already don't like how offset that mount is. I imagine that could present an uneven load to the top but I'm no expert. I'm very interested in seeing how this setup holds up.
