YCW Suspension - SWIFT Springs Master Warehouse Distributor
Trader history for MFactory (0)
San Dimas, CA / Taichung, TW
Hey guys,
we are proud to announce our status as a Master Warehouse Distributor for SWIFT Springs in North America, and exclusive Distributors in Europe & Asia
most popular fitments are in stock and ready to ship out!
Metric Coilover Springs
Swift's innovative designs have made us a staple in the performance tuning world. Our products are the result of over 90 years of experience in industrial spring manufacturing. Our engineers have spent countless hours developing and re-developing our springs, in order to create a product that is light, durable, and compliant, while still maintaining linear spring rates.
Many enthusiasts will swap springs from brand to brand with the only noticeable difference being a stiffer or softer ride. But what if a spring could offer a noticeable increase in traction, smoother weight transfer, better ride quality, lower tire temperatures, and a more predictable feel? The engineers at Swift have taken that "what if" and turned it into reality.
All Swift Springs are manufactured using( H5S.TW.) which is far superior to silicone chrome steel and allows us to wind our springs with less coils, resulting in reduced un-sprung weight and increased stroke
Since the metric system is used widely in the sport compact and road race market, we have introduced the metric line of coilover springs to reduce confusion and to better cater to our customer's needs.
Our metric coilover springs come in various sizes with inner diameters ranging from 60mm (2.25in) to 70mm (2.75in), spring lengths from 127mm (5in) to 280mm (11in), and spring rates from 3kg (168lbs) all the way up to 34kg (1900lbs). Whether you are looking for a comfortable ride for your commuter or a more aggressive setup for your race car, we have the right spring for your application!
View Fitments Here: http://www.ycwsuspension.com/catalog/swift/metric
Helper/Assist Springs
Helper Springs
Unlike our assist springs, our helper springs are specifically designed to have a minimal effect on the spring rate of the main coilover spring. Helper springs allow the spring to stay on mounted on the coilover perch when the shock is under negative or zero load, also known as droop travel. It is ideal to run helper springs on setups where you cannot preload the main spring due to height issues or when experiencing springs coming loose from the coilover perch.
Assist Springs
Like our helper springs, the assist springs are designed to be fully compressed at static height. Every one of our assist springs compress to the exact same height. This allows drivers to change assist springs without resetting the perch on the coilovers so the ride height isn't affected. Heavier rates of assist springs over helper springs are used to fine tune the rebound travel of the shock. These springs can also help preventing loss of traction due to inside wheel lift during hard cornering.
View Fitments Here: http://www.ycwsuspension.com/catalog/swift/helper
Sports Spec-R Lowering Spring Kit
Swift made Sport Springs keeps the quality ride you get from the showroom, and adds improved handling and lower ride height for driving enthusiasts and style minded drivers who demand only the best.
From HPDE events to SCCA competition, Swift Spec-R Sport Springs are made for the track enthusiast looking to take their vehicle to the next level.
Swift Spec-R Sport Springs were engineered with 3 characteristics in mind.
  • Modified ride height compared to Sport Springs to maximize optimal suspension geometry
  • Further increasing the spring rate to enhance overall performance. The increase in spring rate is based on the upper limits of the vehicles factory shock valving
  • Maintaining optimal comfort level for street use
View Fitments Here: http://www.ycwsuspension.com/catalog/swift/spec-r/Ford
Ready to order?
Please contact us for the best possible price. We will beat any legitimate price quote!
If you have any questions, please don't hesitate to ask :)
Wichita
I just bought some spec r springs and was was wondering if you recommend matching them with B6's or B8's. Bilstein recommends the 8's with upgraded and lowered springs but I read on here swift thinks 6's are the way to go so I'm a little confused. Any insight would be helpful. Thank you
