Register
User Tag List
Page 31 of 31 FirstFirst ... 21232425262728293031
Results 301 to 308 of 308
  1. #301
    0%
    Rate Transaction
    Member #
    10408
    Medals
    Join Date
    Aug 2018
    Killeen
    State
    AZ
    Country
    United States
    Posts
    12
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    Quote Originally Posted by Ernie View Post
    I switched the camera portion of this system:
    https://www.amazon.com/gp/product/B0...hps_bw_c_x_2_w
    to this backup camera (Also Amazon)
    Esky EC170-08 Waterproof Night Vision HD CMOS 170°Viewing Field Car Rear View Backup Camera
    I like it so far. The narrow field of view on the original system doesn't work for me.
    Also some cold weather issues that are likely related to the (original) camera. (Didn't work if less than 50 degrees outside temp...) Will let you know about the new camera. Installed it today but may not get cold again here in Texas for a while (90 degrees today).
    Monitor (mirror) is a close fit for the FiST, but it works.
    Love the hybrid (mixed) system so far.
    --Ernie
    How was that camera, I’m just real leery about buying that real cheap stuff off of eBay not saying it’s cheaply made but as cheap as it is monetarily I worry about it. So how how was yours?
  2. #302
    New Member 7 Rep Points
    0%
    Rate Transaction
    Member #
    9367
    Medals
    Join Date
    Jan 2018
    Long Beach
    State
    CA
    Country
    United States
    Posts
    15
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    7
    Anyone recently installed a backup camera on a 14' FiST? I'm looking into it but not wanting to spend an arm and a leg. Any specific camera recommendations would be helpful. Thanks!
  3. #303
    Member 16 Rep Points mindmaster's Avatar
    0%
    Rate Transaction
    Member #
    9912
    Medals
    Earned First 100 Posts
    Join Date
    Apr 2018
    Bogotá D.C
    Country
    Colombia
    Posts
    128
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    16
    Guys! Do anyone know if this chinese full rear sensors work with the camera mod? Also the camera needs to be 720p? Or any specific resolution?
  4. #304
    0%
    Rate Transaction
    Member #
    10943
    Medals
    Join Date
    Nov 2018
    Grays
    Country
    United Kingdom
    Posts
    6
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    I used 332626937827 from eBay & run wires to behind head unit & have not had no problems
  5. #305
    0%
    Rate Transaction
    Member #
    9912
    Medals
    Join Date
    Apr 2018
    Bogotá D.C
    Country
    Colombia
    Posts
    128
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    16
    Quote Originally Posted by mindmaster View Post
    No ideas?
  6. #306
    Member 274 Rep Points brbauer2's Avatar
    Ratings | Rate Transaction
    Member #
    6284
    Medals
    Earned First 100 Posts Earned First 500 Posts Earned First 25 Rep Points Earned First 50 Rep Points Earned First 100 Rep Points Earned First 200 Rep Points
    Join Date
    Nov 2016
    St. Charles
    State
    IL
    Country
    United States
    Posts
    640
    Mentioned
    12 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    274
    No ideas?
    All this mod is doing is telling the car to look for a video signal when in reverse.
    The backup sensors on that unit will signal the included little speaker, so should work as intended.
    Sent from my OnePlus 6T using Tapatalk
    '16 Molten Orange ST 2Nov16 -
    '14 Ruby Red SE 14Feb14 - 2Nov16
    '12 Red Candy SE 23Nov11 - 14Feb14
  7. #307
    0%
    Rate Transaction
    Member #
    10408
    Medals
    Join Date
    Aug 2018
    Killeen
    State
    AZ
    Country
    United States
    Posts
    12
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    Quote Originally Posted by VuDoo View Post
    Well, whatever the reason. there are a few options to try without fear of bricking your system (as long as that is the only thing you change). Just as precaution I did all this while the car was running. I have kids running around and once they see me they will open the doors and climb in. I didn't want to do this in accessory mode and have the car for whatever reason, shut off in the middle of writing to the system if they opened the door or the car automatically shuts off. Once you change the number and click write in FORscan your sync will reset. After it is booted up put it in reverse. It will take a second as it searches for your camera. If no camera is detected will will come up with that screen. if after a few seconds nothing comes up go back into FORscan. Both carguy and I, when it didn't work the first time, put it back to the default values and reset the system before trying another value. I would recommend doing FORscan first. It would make it easier to trouble shoot if, for whatever reason the camera doesn't work.
    Hello all, I have a quick question, I’ve installed a 17 f250 third brake light w/ the camera on my 15 f350 dually. Can I tap into my reverse camera to make that work. If so, I plan on installing a relay to turn it on when I need to see the bed of my truck. I would greatly appreciate some good feedback or maybe some brainstorming. Thanks all
  8. #308
    New Member 33 Rep Points kenweise's Avatar
    0%
    Rate Transaction
    Member #
    9468
    Medals
    Join Date
    Feb 2018
    Lake Orion
    State
    MI
    Country
    United States
    Posts
    84
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    33
    Do you have the link to this thing? I have a hard time seeing out the back because my dirt road keeps the windows filthy. I'd love to have the sensors.
    2016 Shadow Black w/ Cloth Seats
    100% Stock
Similar Threads
  1. $250 to enable the reverse camera
    By CanadianGuy in forum Audio-Video, Electronics, Sync & MyFord Touch
    Last Post: 01-11-2019, 11:31 PM
  2. Review/Install of NAV-TV Backup Camera.
    By D1JL in forum Audio-Video, Electronics, Sync & MyFord Touch
    Last Post: 08-15-2018, 12:55 PM
  3. backup camera
    By digglesworth in forum Audio-Video, Electronics, Sync & MyFord Touch
    Last Post: 02-01-2017, 12:56 AM
  4. New to forum, new owner 2015 FIST - Backup camera mod I'd like to share
    By albertucsb in forum Audio-Video, Electronics, Sync & MyFord Touch
    Last Post: 12-28-2016, 02:57 AM
  5. Fiesta ST Backup camera that plugs into the license plate light
    By rooSTer in forum Audio-Video, Electronics, Sync & MyFord Touch
    Last Post: 03-27-2014, 05:18 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
