Fiesta ST Intercooler Info Thread
dyn085
Vancouver
#62
I don't think they are much larger than the FiST FMIC.
I am pretty sure the FoST IC is larger, but I can't find FiST dimensions to compare. FoST IC info pulled from FocusST.org.
Stock FoST IC
Core Dimensions:
26" x 6.25" x 2.5"
Core Volume:
406.25 in?
Product Photo:
Compared to the Cobb unit-
Cobb
Core Dimensions:
27.5" x 6" x 3"
Core Volume:
495 in?
Mathematically based off of Cobb's statements, I'm assuming the FiST IC is somewhere around 315-325 in? and would place the FoST IC in-between the two. Considering the fact that it's only ~$100 brand-new from Ford and can probably be had used for less from the FoST community, it would be an inexpensive alternative for someone that doesn't need 'maximum' cooling and had no intention of going big-turbo.
Of course, my math could be totally wrong based on my assumption of the FiST's stock IC measurements, and that could make the FoST IC either a better or worse deal for the cost.
razorlab
Bay Area
#64
Well, just by counting cooling rows, the FoST one is larger. 10 rows to FiST's 8.
I'll go measure my OEM FiST fmic at some point today, it's just sitting in the garage.
Hijinx
U.S. Air Force Veteran
Auburn, AL, USA
#67
Hmm... But what about the mounting points? I'm sure the silicone pipes won't mind the 1/2" move but mounting might be the problem.
razorlab
Bay Area
#69
Focus ST intercooler part number
CV6Z-6K775-A
MSRP $138.63
Tasca has it for $91.50
razorlab
Bay Area
#71
Intercooler
Core 27"x5"x2"
40" from charge pipe to pipe in/out
Fist
Ok I just went out and measured my OEM FiST intercooler.
Core is 27.5 x 5.25 x 2
Top mounting points are 32" apart
Widest point, being the outlets are 40" apart
So your measurements where a little off. ;)
The FoST mounting points are very different so that might make an install slightly more difficult. Also the extra .25 in height over the cobb unit might make it a very tight fit. I know my AIRTEC makes use of pretty much all vertical space and it's a tight fit. I wish I measured my AIRTEC before I installed it.
Sourskittle
Lakeland
#72
I was just fixing to post they were not down to the MM, lol. Measured it quick on the car, next to a 26x15x4.5 I have around the house.
razorlab
Bay Area
#73
So using dyn085's format:
Stock FiST IC
Core Dimensions:
27.5" x 5.25" x 2"
Core Volume:
288.75 in
Stock FoST IC
Core Dimensions:
26" x 6.25" x 2.5"
Core Volume:
406.25 in
33.8129% difference over OEM FiST IC
Cobb IC
Core Dimensions:
27.5" x 6" x 3"
Core Volume:
495 in
52.6316% difference over OEM FiST IC
19.6949% difference over OEM FoST IC
5.6075% difference over ATP IC
ATP IC
Core Dimensions:
24" x 6.5" x 3"
Core Volume:
468 in
47.3736% difference over OEM FiST IC
14.1264% difference over OEM FoST IC
Sourskittle
Lakeland
#74
So 30% increase in volume for free to $100? Wow... That is pretty good for a stock turbo car... Plus.. Dealership would prob never realize it = warranty :)
R
rodmoe
wausau
Thread Starter #76
And I think I sticky that one without reding this one LOL
Kip2MyLou
Gaithersburg
#78
Is it worth getting the charge pipes from cobb? Are they really necessary immediately if an intercooler is in the immediate future? Or is it okay to run the intercooler with stock pipes? I'm asking because I would save that cash and invest in their intake when it comes out.
R
rodmoe
wausau
Thread Starter #79
On the stock turbo the factory charge pipes will be just fine ..
