ST200 airbox vs stock box
mkokoszka
Chicago, IL, USA
Is there a gauge on my Cobb AP that measures how much air is getting to the intake or engine? Curious to see what the quantifiable difference would be between my stock airbox and the ST200. Thanks.
Nope* You would need an anemometer. The only thing Ap3 does is intake air temp I do believe. The St200 is essentially the same boxbplus the air inlet hose from the bottom that you can route to a fresh cold air area of your choice.
Nope* You would need an anemometer. The only thing Ap3 does is intake air temp I do believe. The St200 is essentially the same box minus the air inlet hose from the bottom that you can route to a fresh cold air area of your choice.
I think you meant plus. Or you meant to say the stock box is the same as the ST200 minus the air inlet hose from the bottom.
I was at work for a Double* I was most likely on Autopilot! But unlike Tesla I didn't CRASH*....Hehe
Capri to ST
CHAPEL HILL, NC, USA
The Mountune airbox is exactly the same functionally as the ST200 airbox, it's just made out of aluminum instead of plastic. This is a quote from the Mountune website regarding their airbox, where they claim that it provides a 21% increase in air flow over the stock one-
"The mountune Fiesta ST Induction Upgrade includes a uniquely constructed aluminum air box with a secondary cold air feed point. Additionally, the air box has been engineered with features that reduce the delta pressure drop by 2kPa that when coupled with the included mountune high flow air filter, provide a 21% increase in airflow."
https://www.mountuneusa.com/Induction-Upgrade-Kit-Fiesta-St-2014-18-p/2364-cais-aa.htm
Mountlake Terrace, WA, USA
If you get the Mountune or the ST200 box you will draw air from 2 locations. One is the stock location, the plenum above the radiator which is good for keeping things quite but obviously compromised because it is heated by having the radiator right below it. The 2nd location is down by the fog light which is clearly better. Both locations will combine in the airbox for a slightly warmer than ambient temperature air mix heading to the turbo. This clearly better than stock USDM. The turbo will be sucking this air in just like sucking a milkshake through a straw.
If you keep the stock USDM airbox and add a Big Mouth, the air is coming from in front of the radiator and is not heated by it, thus giving you a cooler charge of air. When you are moving, that cooler air will also lightly pressurize the airbox and the tube all the way to the turbo inlet. Instead of the turbo sucking to get air, the air will be trying to get into turbo on it's own. This may or may not help make any power but what it does do, is spool the turbo sooner thus increasing throttle response. Imagine the milkshake is now being pushed through the straw. That is less work for the person/turbo doing the sucking.
Now if you add the Big Mouth to the ST200/Mountune intake you have 2 locations receiving ambient air. The restriction is less and the air is cooler than in example 1 but you do not get the positive pressure advantage from example 2.
Taking all this into consideration my choice is Big Mouth with stock airbox. I do feel like the throttle response improved and the car feels peppier getting on on-ramps or just passing someone on the freeway.
As an alternative, one could take a ST200/Mountune/DIY add a hose down to your fog light location and install it so outside air would forced into the tube. Then block the stock inlet location inside the airbox (even with duct tape) and it would provide a similar pressurized effect as the Big Mouth with stock airbox. This would be very cheap for you budget minded folks but I think the Big Mouth is a shorter path with less pressure loss.
FYI, I don't work for Velossa Tech, Mountune or any other car related organization. This just my opinion.
anticon
Sherwood
I agree with 4DGC. Some other considerations; rain/road spray water through the big mouth, big mouth slightly blocks radiator for cooling.
No one needs to worry about water coming through and harming anything at all. I Run both the Big mouth and ST200 airbox with an ITG filter on a Gen2 GTX through all 4 seasons. No issues whatsoever....just an FYI for any of you on the fence about purchasing either option or Both. Yes..... Yes I have Hit 9k post as I see this now! Yay ME!
Also, it you must drive through HEAVY, hanging in the air type dust (like I do when working ARA rallies), the Big Mouth gives a much more direct path for it to clog up the filter than a factory box alone, or the ST200/Mountune if you don't route the hose to the foglight external opening. [:(]
(WHY I will not install one, even besides the radiator blockage.)
