Welcome to Fiesta ST Forum, is this your first visit? Click the "Create Account" button now to join.
Register
See the top rated post in this thread. Click here
User Tag List
Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
Thread: I moneyshifted my 2015 ST
  1. #1
    New Member 5 Rep Points Arcthum's Avatar
    0%
    Rate Transaction
    Member #
    9340
    Medals
    Join Date
    Jan 2018
    Calgary
    Country
    Canada
    Posts
    27
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    5
    Guest-only advertisement. Register or Log In now!
    Yes, I know what I did was worse than death itself. I was just cruising on a cold Saturday night when I stupidly shifted from 2nd(around 3,000rpms that time) to 1st. I felt the wheels lock up and managed to depress the clutch immediately. I saw the RPM jump to around 4,500 to 5,000. Then shifted to a very safe 4th gear.
    Should I get an engine diagnosis at the dealership? Because I truly hope that I just shortened the life of the clutch and not any other component. I’ve been feeling my ST since the day of the incident and I still feel that my clutch is still solid. There are no knocks, misfires, nor a CEL on my dash. But I still feel terrible for what I did. Should I take her in?
  2. #2
    Member 141 Rep Points felopr's Avatar
    Ratings | Rate Transaction
    Member #
    1806
    Medals
    Earned First 100 Posts Earned First 500 Posts Earned First 25 Rep Points Earned First 50 Rep Points Earned First 100 Rep Points
    Join Date
    Nov 2014
    JD
    State
    PR
    Country
    United States
    Posts
    619
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    141
    i wouldnt count that as a money shift imo,
    one could have shifted to 1st smoothly if you had rev-match the engine to 5k rpm, from your alleged 3k rpm on 2nd
    for me, money shift is when you downshift and puts you over your redline.
    for example 2nd gear 6k rpm and shifted to 1st, that is money shift, at least for me
    i wouldnt worry about it
    Last edited by felopr; 01-16-2018 at 02:53 AM. Reason: better wording cuz i am a noob
    2015 Performance Blue Fiesta ST, Recaros, Sunroof
    Cobb AccessPort (custom tune), NGK LTR7IX-11 (1 step colder), Resonator Delete, Turbosmart EM Plumb-back, Ramair blue intake silicone hose
    Velossa Tech Big Mouth Performance Blue, Ramair crossover pipe gold taped, Whoosh hotside J charge pipe, Whoosh Blue Silicone charge hoses , Whoosh symposer delete
    PowerFlex RMM inserts, Poweflex Motor and Transmision bushing inserts, Damond Oil Catch Can w/VTA & nylon sleeves, ST200 Airbox with Ramair filter
    Hawk 5.0 brake pads, Mishimoto radiator hoses, LaminX headlight protectors, OEM all weather mats inc/ trunk, Maxon Design front lip v2, CPE FMIC
    Boomba short throw tranny kit, Boomba tranny solid bushings, Rota titans Gold 17x7.5 , Mountune Radiator, TB Performance stage 3 braces
  3. #3
    0%
    Rate Transaction
    Member #
    9340
    Medals
    Join Date
    Jan 2018
    Calgary
    Country
    Canada
    Posts
    27
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    5
    Quote Originally Posted by felopr View Post
    Well sadly I would count it as a misshift. The wheels did lock up a bit though, since the road had some ice and snow.
  4. #4
    Member #
    1806
    Medals
    Join Date
    Nov 2014
    JD
    State
    PR
    Country
    United States
    Posts
    619
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    141
    here is a money shift for you
  5. #5
    Member 99 Rep Points
    Member #
    8231
    Medals
    Earned First 100 Posts Earned First 25 Rep Points Earned First 50 Rep Points
    Join Date
    Jul 2017
    Fontana
    State
    CA
    Country
    United States
    Posts
    483
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    99
    Yeah you are over reacting
    The dealer would love for you to take it in So they can tell you it needs a new clutch, flywheel and trans..when you clearly told us nothing is wrong
  6. #6
    Senior Member 506 Rep Points
    0%
    Rate Transaction
    Member #
    8050
    Medals
    Earned First 100 Posts Earned First 500 Posts Earned First 1000 Posts Earned First 25 Rep Points Earned First 50 Rep Points Earned First 100 Rep Points Earned First 200 Rep Points
    Join Date
    Jun 2017
    Spring
    State
    TX
    Country
    United States
    Posts
    1,314
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    506
    You're right, it is a miss shift. It is definitely not a money shift. Your car is fine, but if you want to waste some money, feel free to take it to a dealership.
  7. #7
    Member 133 Rep Points Zissou's Avatar
    Member #
    1380
    Medals
    Join Date
    Aug 2014
    Charlottesville
    State
    VA
    Country
    United States
    Posts
    530
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    133
    Revving to 4000 rpm is not a money shift.
    2014 Tuxedo Black Fiesta ST, Recaros, Nav, Sunroof SOLD
    Cobb AccessPort V3 (Stage 3), Cobb Downpipe, Cobb Exhaust Hangers, MAP Cat Back Exhaust, Injen Intake,
    Deadhook Motorsports FMIC (factory-fit, black), Cobb RMM, DIY Sound Symposer Delete, MBRP Hot side charge pipe,
    Velossa Tech Big Mouth, Damond Oil Catch Can w/VTA & nylon sleeves, H&R Camber bolts, Mountune lowering springs
    2016 Mustang GT, California Special, Roush Axle Back, 3.55
    2012 Ducati Monster 1100 Evo
  8. #8
    New Member 32 Rep Points alexwlwsn's Avatar
    Member #
    8915
    Medals
    Join Date
    Oct 2017
    Columbia
    State
    MD
    Country
    United States
    Posts
    82
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    32
    Money shift is called money cause you just blew something up! You just oopsed into the wrong gear when casually driving about. Best thing to do would to be to pat your dashboard, say "sorry [insert car name here]", and move on.
    2016 Purple Drank Tuned Fiesta ST
  9. #9
    Administrator Staff Team 1039 Rep Points BoostBumps's Avatar
    0%
    Rate Transaction
    Member #
    1333
    Medals
    Earned First 100 Posts Earned First 500 Posts Earned First 1000 Posts Earned First 2000 Posts Earned First 25 Rep Points Earned First 50 Rep Points Earned First 100 Rep Points Earned First 200 Rep Points Earned First 1500 Posts and 300 Rep Points Earned First 2000 Posts and 400 Rep Points
    Join Date
    Aug 2014
    Palm Desert
    State
    CA
    Country
    United States
    Posts
    4,208
    Mentioned
    71 Post(s)
    Tagged
    1 Thread(s)
    Likes Received
    1039
    Your fine...
    If you didn't shoot past redline and break something then it's not a money shift....
    Urban Dictionary: Money Shift
    SOLD: '14 Fiesta ST - RaceRed | Recaro | NAV | MoonRoof | Red Calipers
    COBB - AP | ATR | TBE | FMIC | IC Pipes | Sport Springs
    CPE - CAI JBR - OCC Kit CFM - Baffled Breather Cap DiY - Symposer Delete | RAM Intake Duct
    SPARCO - Assetto Gara Wheels 17x7 Rally Innovations - Front Splitter BOOMBA - Short Shift | Wing Risers
    LatheWerks - Hybrid Piston Shift Knob No Pistons - Dead Pedal | Battery Tie-Down | Pedal Spacer
    VLED - Fogs | Domes 3M - Window Tint Perrin - Shorty Antenna
    Self-Tuned: e30 | 220whp | 325wtq (V-Dyno) Selectable Map Slots:
    e10 | e20 | e30 | ECO
    2018 M7 Corvette Stingray
    Watkins Glen Gray / NPP / PDR / NAV / CF Badges / Black Wheels / Tinted Windows and Markers / XPEL PPF / Splash Guards / Z51 Spoiler / Side Skirts
  10. #10
    0%
    Rate Transaction
    Member #
    9340
    Medals
    Join Date
    Jan 2018
    Calgary
    Country
    Canada
    Posts
    27
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    5
    Quote Originally Posted by alexwlwsn View Post
    I guess I'm not the only one that does this ritual haha. Pretty comforting replies all, cheers!
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
