Register
User Tag List
Results 1 to 7 of 7
  1. #1
    Member 105 Rep Points XuperXero's Avatar
    0%
    Rate Transaction
    Member #
    505
    Medals
    Earned First 25 Rep Points Earned First 50 Rep Points Earned First 100 Rep Points
    Join Date
    Mar 2014
    Wuxi
    Country
    China
    Posts
    582
    Mentioned
    13 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    105
    PSA: Powerflex passenger side transmission mount FAILED
    I noticed the mount protruding out one day when looking under the hood.
    Estimated 5000km of driving. Transmission side is fine though.
    I would recommend using a thick metal wire to wrap it instead of the rubber ring. Rubber ring deteriorated and could no longer keep it tightly wrapped.
    I took both out anyway as I may sell the car.
    2013 Spirit Blue 3Dr Euro Spec
    4300K LED Headlights
    BMS Oil Catch Can
    Mountune Induction Hose
    SCOE LED Reverse and Brake Lights
    DIY LED Rear Hatch Light, Intercooler mesh grill, 10mm Gas Pedal Spacer
    Boomba Racing 270g Shift Knob, RMM, Shifter & Transmission Cable Bracket Bushing, Short Shift Lever, Transmission Adapter Plate
    BC BR Series Coilovers 5/3kg
    TADDEO 20mm F/15mm R spacers
    Forged BOV Adapter
    Goodridge SS Brake Lines
    REVO Stage 1 98 RON Tune
    Hard Race LCA
    AP Racing 5000+ BBK
    KO Wing Ricer
  2. #2
    Senior Member 856 Rep Points TyphoonFiST's Avatar
    Ratings | Rate Transaction
    Member #
    3563
    Medals
    Earned First 25 Rep Points Earned First 50 Rep Points Earned First 100 Rep Points Earned First 200 Rep Points
    Join Date
    Aug 2015
    Blaine
    State
    MN
    Country
    United States
    Posts
    3,089
    Mentioned
    33 Post(s)
    Tagged
    1 Thread(s)
    Likes Received
    856
    Or you could use a metal Zip tie...IMO...
    Is this your bush? Are you king of the forest?
  3. #3
    New Member 30 Rep Points
    0%
    Rate Transaction
    Member #
    7707
    Medals
    Join Date
    Apr 2017
    Southwest
    State
    FL
    Country
    United States
    Posts
    87
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    30
    Or use the cp-e motor mounts cause they are badass!
  4. #4
    Senior Member 818 Rep Points jeff's Avatar
    Member #
    3995
    Medals
    Join Date
    Nov 2015
    Evans
    State
    GA
    Country
    United States
    Posts
    1,285
    Mentioned
    41 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    818
    Quote Originally Posted by XuperXero View Post
    Thanks for this. I just installed both Powerflex mount inserts, and heard that this could happen.
    Quote Originally Posted by TyphoonFiST View Post
    I look at my engine bay about every day, so I'll keep an eye on it...good fix!
    Quote Originally Posted by FiSTerTheGrouch View Post
    I think the inserts provided they hold up are a good alternative to those who don't want the added NVH of a true mount upgrade. I've ridden in a FiST with upgraded mounts, too loud/rattley and pricey for my taste. But they are definitely badass.
    Hey, check out my build thread!
  5. #5
    Member 141 Rep Points felopr's Avatar
    Member #
    1806
    Medals
    Join Date
    Nov 2014
    JD
    State
    PR
    Country
    United States
    Posts
    619
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    141
    When I installed mine, I put the supply rubber ring and a ziptie over it, one less thing to worry about
    2015 Performance Blue Fiesta ST, Recaros, Sunroof
    Cobb AccessPort (custom tune), NGK LTR7IX-11 (1 step colder), Resonator Delete, Turbosmart EM Plumb-back, Ramair blue intake silicone hose
    Velossa Tech Big Mouth Performance Blue, Ramair crossover pipe gold taped, Whoosh hotside J charge pipe, Whoosh Blue Silicone charge hoses , Whoosh symposer delete
    PowerFlex RMM inserts, Poweflex Motor and Transmision bushing inserts, Damond Oil Catch Can w/VTA & nylon sleeves, ST200 Airbox with Ramair filter
    Hawk 5.0 brake pads, Mishimoto radiator hoses, LaminX headlight protectors, OEM all weather mats inc/ trunk, Maxon Design front lip v2, CPE FMIC
    Boomba short throw tranny kit, Boomba tranny solid bushings, Rota titans Gold 17x7.5 , Mountune Radiator, TB Performance stage 3 braces
  6. #6
    Senior Member 240 Rep Points
    0%
    Rate Transaction
    Member #
    9500
    Medals
    Join Date
    Feb 2018
    Tigard
    State
    OR
    Country
    United States
    Posts
    1,387
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    240
    FYI, for those who may stumble on this thread, the title is wrong: The passenger side is the OPPOSITE of the transmission (driver side)... This screwed me up and confused me before I knew... So the 3 are RMM/roll restrictor, passenger side upper and transmission/driver side upper... And yes, get a bag of thin zip ties from Harbor Freight for like $2 and use one to keep the ring closed fully, have no idea why they think a rubber band will do it but it's worthless and does not at all... for $32 for a piece of poly you'd think they would at least include what you need to install it right.
    '17 Magnetic, black wheels/red calipers only option - New Feb, '18. Dizzy V2 93/e30 with Cobb TC at 3 as daily smooth tune, Stratified v4.00 93 octane with Stratified Optimal TC for aggressive driving. Torque Solutions 75a RMM, Mojo Mfg short shift kit, drop-in filter w/cold air shroud cutout. Whoosh silicone Symposer delete, Magnaflow glasspack muffler with 9" resonated tip, Powerflex passenger side engine mount insert with ARP bolt upgrade, step colder NGK plugs gapped at .0275. Driver side/trans mount insert and TB Performance Traction Bar on hand waiting to go in.
    FYI - 92 octane e10 pump premium is very close to if not actually 93 octane, start with a 93 tune and datalog from there or you're leaving free power on the table over running 91 tunes.
  7. #7
    Member 253 Rep Points Quisp's Avatar
    0%
    Rate Transaction
    Member #
    3955
    Medals
    Join Date
    Nov 2015
    Davenport
    State
    FL
    Country
    United States
    Posts
    893
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    253
    Quote Originally Posted by danbfree View Post
    Xero is in China hence the swap.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
