Found this cool $50 short shift kit - guy makes them himself - Mojo Mfg.
borborpa
Central PA
#48
Installed the short shift adapter today. It's not fun for a guy with big hands!! But I was able to get it with a little blood, sweat, and curse words. Feels great and makes the shifting much better! This the the throw it should be from the factory!!
cxwrench
Marin County
#49
This looks pretty cool. If you pull the battery is there anything you have to do when you hook it back up? Does it put everything back to default settings?
Business6
Northern UT
#50
I had to get in that area a couple weeks ago and pulled the battery but nothing reset other than the 1 touch window down. I'd absolutely expect it to reset things, though.
danbfree
danbfree
Tigard, Oregon, USA
Thread Starter #54
May need to get on of these... my VUDU shift plate won’t fit together over the shifter arm.
LOL! I LITERALLY just found your other post about that! Yes, this is a great simple option, I'm VERY happy I did this... Now I never could figure out the "swing it over the arm with one bolt on", I just sandwiched it in 2 pieces and bolted in..
redmoe
Phoenix
#55
Did you guys pull the battery box forward? I found it pretty easy/helpful to leave the bolt it as a pivot on the single bolt side. You do need to engage very few threads to leave enough height to clear the arm.
The VUDU does not have the notch cut out like the mojo so you need to get the top half over the stock ball mount.
danbfree
danbfree
Tigard, Oregon, USA
Thread Starter #56
Yeah, I followed the Mojo video directions, I pulled it forward but it was more difficult on my '17 with looks like stiffer cables and stuff involved... But ya, I'm just not a good mechanic I guess, I struggled with even just a few threads on that single bolt side, I found it far easier to just sandwich it in in 2 pieces, no reason not to just do it that way if one finds it easier...
Middlesex county
#59
I installed mine last night. Great product and the improvement in shifting is awesome. I didn’t have to remove my battery tray I just used a long 5mm ball end allen on a swivel and had no issues. Took 10 minutes tops.
alexrex20
Spring
#60
I can't believe I'm just now seeing this. hopefully he makes more shift extensions. I'm keen to try one of those out. Might be a perfect complement to a short shift kit and weighted knob.
