Welcome to Fiesta ST Forum, is this your first visit? Click the "Create Account" button now to join.
Register
See the top rated post in this thread. Click here
User Tag List
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Stuck factory oil filter
  1. #1
    Member 29 Rep Points
    0%
    Rate Transaction
    Member #
    6577
    Medals
    Earned First 100 Posts Earned First 25 Rep Points
    Join Date
    Dec 2016
    Quebec
    Country
    Canada
    Posts
    113
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    29
    Guest-only advertisement. Register or Log In now!
    Wtf do they use to torque that damn filter at the factory? It's so tight, I can't even see the rubber seal. I'm at 1250km so I'd like to do my first oil change. So far I tried:
    Cup style wrench: slipped like crazy even if it's the right size
    Metal strap wrench: It hooked fine but when I applied torque to unscrew, it began to crush the filter instead of unscrew it.
    Rubber strap wrench: broke the strap.
    I tried to spray penetrating oi on the seal, but it did not seem to do much.
    I did not try the "poke a hole with a screwdriver and twist" method because I'm afraid that I'll just rip the filter and be stuck with a real mess.
    Anyone else did have a first filter torqued by Hulk?
  2. #2
    Senior Member 879 Rep Points koozy's Avatar
    Ratings | Rate Transaction
    Member #
    235
    Medals
    Earned First 100 Posts Earned First 500 Posts Earned First 1000 Posts Earned First 2000 Posts Earned First 25 Rep Points Earned First 50 Rep Points Earned First 100 Rep Points Earned First 200 Rep Points Earned First 1500 Posts and 300 Rep Points Earned First 2000 Posts and 400 Rep Points
    Join Date
    Dec 2013
    Los Angeles
    State
    CA
    Country
    United States
    Posts
    2,011
    Mentioned
    47 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    879
  3. #3
    0%
    Rate Transaction
    Member #
    6577
    Medals
    Join Date
    Dec 2016
    Quebec
    Country
    Canada
    Posts
    113
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    29
    Thanks a lot! Will have to order this tool online, I did not see anything like that in any shop around.
  4. #4
    Member 231 Rep Points Capri to ST's Avatar
    0%
    Rate Transaction
    Member #
    4050
    Medals
    Earned First 100 Posts Earned First 500 Posts Earned First 25 Rep Points Earned First 50 Rep Points Earned First 100 Rep Points Earned First 200 Rep Points
    Join Date
    Dec 2015
    CHAPEL HILL
    State
    NC
    Country
    United States
    Posts
    552
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    231
    Someone joked that they are applied by gorillas.
    2016 KONA BLUE FIESTA ST
    MP 215, RECAROS, TD PRO RACE 1.2 WHEELS
    1995 ACURA NSX-T
  5. #5
    Member 141 Rep Points felopr's Avatar
    Member #
    1806
    Medals
    Join Date
    Nov 2014
    JD
    State
    PR
    Country
    United States
    Posts
    619
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    141
    2015 Performance Blue Fiesta ST, Recaros, Sunroof
    Cobb AccessPort (custom tune), NGK LTR7IX-11 (1 step colder), Resonator Delete, Turbosmart EM Plumb-back, Ramair blue intake silicone hose
    Velossa Tech Big Mouth Performance Blue, Ramair crossover pipe gold taped, Whoosh hotside J charge pipe, Whoosh Blue Silicone charge hoses , Whoosh symposer delete
    PowerFlex RMM inserts, Poweflex Motor and Transmision bushing inserts, Damond Oil Catch Can w/VTA & nylon sleeves, ST200 Airbox with Ramair filter
    Hawk 5.0 brake pads, Mishimoto radiator hoses, LaminX headlight protectors, OEM all weather mats inc/ trunk, Maxon Design front lip v2, CPE FMIC
    Boomba short throw tranny kit, Boomba tranny solid bushings, Rota titans Gold 17x7.5 , Mountune Radiator, TB Performance stage 3 braces
  6. #6
    Senior Member 873 Rep Points jeff's Avatar
    Member #
    3995
    Medals
    Earned First 100 Posts Earned First 500 Posts Earned First 1000 Posts Earned First 25 Rep Points Earned First 50 Rep Points Earned First 100 Rep Points Earned First 200 Rep Points
    Join Date
    Nov 2015
    Evans
    State
    GA
    Country
    United States
    Posts
    1,353
    Mentioned
    45 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    873
    Quote Originally Posted by Alkoran View Post
    When I was 16 I saved up $7000 and bought a used 300zx turbo 1984 model. Epic car, though the A/C never worked no matter what I spent to fix it. The day came to change the oil. My dad attempted to coach me in this process. What a dad. Hulk has previously torqued the filter on that thing so dad pulled out the screwdriver method. One hour later the sun had set, we could not see in the dark; the filter was a horrible mess of gouged, shredded metal; there were metal shards everywhere, blood everywhere from the cuts, oil everywhere, my dad was inventing new cuss words, that filter was reduced to a male thread and had not budged, and I decided I never wanted to be alive anymore. About three days later he somehow had that thing off, I never knew how so.
    Get the tool mentioned in the thread by @koozy, I bought something very similar to that a few decades ago and it has been used dozens of times on my cars, it pulls any filter right off. It's a PITA to get on sometimes because you have to manually tighten the "fingers" onto the filter while applying counterclockwise pressure, and find the right extensions to get leverage, if there is little room to work and things are oily and slippery it takes some dexterity, but it works.
    Hey, check out my build thread!
  7. #7
    Senior Member 498 Rep Points
    0%
    Rate Transaction
    Member #
    8050
    Medals
    Join Date
    Jun 2017
    Spring
    State
    TX
    Country
    United States
    Posts
    1,302
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    498
    Quote Originally Posted by felopr View Post
    This is the only thing I was able to get the filter off with. I tried the cup style and a strap wrench to no avail. The pliers type worked a treat.
  8. #8
    Member #
    1806
    Medals
    Join Date
    Nov 2014
    JD
    State
    PR
    Country
    United States
    Posts
    619
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    141
    Quote Originally Posted by alexrex20 View Post
    they work great, and cheap
  9. #9
    0%
    Rate Transaction
    Member #
    8148
    Medals
    Join Date
    Jun 2017
    Decatur
    State
    IL
    Country
    United States
    Posts
    22
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    I've hot glued and even epoxied on filter end wrenches with good luck. Also I never tried it but loosening with an air impact gun might provide beneficial shock to break the seal loose. Heat? Never run out of ideas...
  10. #10
    New Member 10 Rep Points
    0%
    Rate Transaction
    Member #
    9100
    Medals
    Join Date
    Dec 2017
    Roseville
    State
    CA
    Country
    United States
    Posts
    25
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    10
    To remove the factory oil filter on my first change after several unsuccessful attempts with several different tools, I ultimately resorted to using a small C-clamp.
    I torqued the clamp down so to the point it was pinching the filter sides, causing it to dent. I then used the extra leverage I got from the clamp to just barely break the filter free.
    I recently did my second oil change, and the filter was surprisingly hard to get off again, even though I made it hand tight when installing.
    I'll have to invest in one of these for next time.
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
