HPS Black Shortram Air Intake + Heat Shield for 14-15 Ford Fiesta ST 1.6L Turbo
Trader history for Redline360 (0)
Bay Area
HPS Wrinkle Black shortram air intake kit with heat shield fits 2014-2015 Ford Fiesta ST 1.6L Turbo . Dyno proven performance gains - increase horsepower +7.6 Whp , torque +9.3 Ft/lbs and improve throttle response. Bolt-on easy installation, no modification. CARB Exempt: No.
Please click here to order: HPS Fiesta ST Intake
Built for performance and show, HPS Wrinkle Black shortram air intake kit for 2014-2015 Ford Fiesta ST 1.6L Turbo offers a free-flowing 2.75" mandrel-bent aluminum tube induction system designed to produce dyno proven performance gains +7.6 Whp horsepower, +9.3 Ft/lbs torque and improve throttle response while maintaining safe air fuel ratio. The heavy duty powder coated steel heat shield included in the kit blocks out the heat from the engine and maximize the cooling effect. Compare to the cold air intake, HPS short ram cool air intake is a convenient way to change your intake in case of rainy days where water might be inducted into your cold air system. The included installation instruction has clear pictures and description to guide the installer throughout the whole process. The kit does NOT require tuning and does not trigger CEL light. No modification is required during the installation. HPS light weight 2.75" mandrel-bent aluminum alloy piping replace the stock restrictive air box and optimize the air flow with long lasting durability. HPS shortram air intake kit features HPS signature race proven reinforced silicone hoses and industrial grade 100% stainless steel T-bolt clamps, which ensure the durability and reliability during the extreme driving condition. The included K&N High-Flow conical air filter designed to provide increased surface area and dust capacity. This extra surface area provides even more airflow at lower restriction than a standard replacement filter that is limited to the size of the factory air box. The oversize air filter also captures more dirt increasing the service life before a cleaning is required (up to 100,000 miles).
HPS Shortram Air Intake Kit Features and Specification
- Delivers dyno proven performance gains +7.6 Whp horsepower, +9.3 Ft/lbs torque and improve throttle response. Does not require tuning after the install.
- Features HPS signature race proven reinforced silicone hoses and industrial grade 100% stainless steel T-bolt clamps
- 2.75" mandrel-bent aluminum piping replace stock restrictive air box and optimize the air flow
- Includes K&N High-Flow, Washable/Reusable Air Filter which is backed by Million Mile Limited Warranty
- Includes easy to follow step-by-step installation guide with clear pictures and instruction to guide the installer throughout the whole process.
- No modification is required during the installation. Does not trigger CEL light
- Color: Wrinkle Black
- CARB Exempt: No
- System Type: Shortram air intake with heat shield
- Vehicle Application: 2014-2015 Ford Fiesta ST 1.6L Turbo
