So, hopefully you guys don't mind if I go back to "cheap alternatives" as I was originally intending when I started this thread, for those who are all about the DD and Morimoto's, feel free to ignore.
So AliExpress has some some surprisingly decent options starting as low as $25 for the entire assembly and LED's complete... there are even cheaper ones but these claim 2000lm output each side and look like could be at least "better than stock" for VERY cheap. When searching out there, sometimes it's easier to just use 2014 for the year Fiesta, no matter which year you actually have as they are all the same... or can try by using 3.5" or 89/90mm for the size on key words to search with or look for to confirm fitment... Since we use a very common size you can also search for a 2013 Mustang to get more results too, just some strategies for those who want to geek out and try to find lots of options before narrowing down.
These don't look bad at all for $24:
https://www.aliexpress.com/item/Bui...RL-White-12V-High-Bright-For/32904459709.html
Not going to be as good as those $150+ ones, but again, likely decently better than stock for super cheap... Sinc eI have already invested in yellow Lamin-X, I'm going to get some 4300k bulbs to put in the factory housings to get a more true yellow color out of them.
