While the springs are definitely the primary determining factor for the ride height, I believe the height will still vary slightly between different shocks. My Str.Ts with stock springs sit slightly lower than with the stock shocks on stock springs.
At first I thought the reason my car seemed to sit lower than it should was because my previous 195/55/15s were actually wider at a 200/55/15. But now that I have 195/60s on it seems a bit more obvious that it is sitting lower than it should.
Not really a problem for me per se because I like the look but I may need to get a stiffer shock eventually because the shorter travel (and closer clearance) is causing me to rub a lot more than it would with stock shocks. Otherwise I really like the ride on the 195/60s.
