Peron Aux Fuel System Installed
slopoke
slopoke
Livermore
Thread Starter #21
Thought he was the next best thing since sliced bread. Sounds like a problem about to happen.
We need more information as to what he did and when he did them. We don't know if he just installed the aux fuel and tired to run it, without installing a base tune map into the ECU and a map into the Split Second controller.
I know that the controller will fire the injectors at idle, that's how I tested each injectors to see if they were firing. The injectors normally don't fire until you are WOT, that's the condition that normally needs the extra fuel. When the Split Second controller did not have a map loaded into it, I didn't try to run the car with all of the injectors connected. I connected and disconnected the injectors one at a time to see if the engine bogged, if it bogged I knew that the injector was firing and moved onto the next one and so on.
That's what I have also done ....by unplugging an injector the car will run rich and idle will change. Then plug it back in and move to the next injector and repeat until all are verified are functioning properly. That is how I have checked to see if they were all functioning properly. Loading the Tune can be cumbersome also. I also took Slopokes advice and installed an LED light to let me know that the system is functioning! Great Idea! I'd recommend this also to others.
