What brace is this?
NANAIMO
Hey guys, I just picked up a used set of Bilstein coilovers off of Craigslist. Guy chucked in some sort of brace for free that he was given by the previous owner of his car. He said he wasn't sure what it was for but that it might be a rear torsion bar.
[scratch] I've searched online for one similar but haven't found anything. It doesn't line up with the holes in the rear axle so I'm not sure if it's some kind of custom thing the guy made or if it's just off something else and the guy was lying.
Any help would be appreciated.
Murray
I’m assuming this is a trunk brace? If so, it looks like a one off to me...
C
NANAIMO
Thanks guys, I guess it is a TB brace that has seen better days. It's been bent out of shape pretty badly. I was able to stand on it and get it to straighten out slightly. I'm not sure if it's worth using in it's current state.
If I was you....I'd blast that old paint off or just re-prime it and paint it as is and get some new nuts and bolts and install that piece of free performance bracing! [wrenchin] DON'T THROW IT AWAY!
alexrex20
Spring
I guess TB should've used chromoly (like Pierce) instead of mild steel. [emoji23][emoji1787][emoji23]
koozy
Los Angeles, CA, USA
I personally wouldn't put it on if it can't be bent straight to align perfectly with the mounting holes. With it bent, there is potential preload that would be transferred to the twist beam. Also if it's easily bendable one has to wonder how effective it is trying to hold a twist beam together from flexing. There's probably some reduction, but a better material should have been chosen and tubular as opposed to a flat bar.
ron@whoosh
Vendor
Las Vegas
agree 100%
I'd have concerns why it's bent and would not ever install anything bent on my suspension intentionally
C
NANAIMO
Yeah it's incredibly cheesy how easily it bends. Apparently it was on a track car but even still. It looks like it ended up buckling due to stress. I guess it was made out of dog food tin cans.
I might just chuck it in the bin and order a new one.
alexrex20
Spring
It probably bent in storage. It would not bend that way from normal use. If you order new, get Pierce not TB
