Register
User Tag List
Results 1 to 7 of 7
  1. #1
    Member 49 Rep Points
    Ratings | Rate Transaction
    Member #
    4516
    Medals
    Earned First 100 Posts Earned First 25 Rep Points
    Join Date
    Feb 2016
    Morton Grove
    State
    IL
    Country
    United States
    Posts
    257
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    49
    Will weather affect e-tuning?
    I just got my MRX turbo kit installed and now it's time to tune. I'm in Chicago and can't expect consistently decent weather until June. Like stated in the title, will weather have a large effect on my end result? If I were to tune now or early spring would my tune be all wonky in the summer?
    Thanks for the help, guys.
    Deporacing DP, Deporacing IC, Mountune CBE, Damond OCC, GFB DV+,Cobb RMM, and tuned by Stratified
  2. #2
    Senior Member 1118 Rep Points TyphoonFiST's Avatar
    Member #
    3563
    Medals
    Earned First 100 Posts Earned First 500 Posts Earned First 1000 Posts Earned First 2000 Posts Earned First 25 Rep Points Earned First 50 Rep Points Earned First 100 Rep Points Earned First 200 Rep Points Earned First 1500 Posts and 300 Rep Points Earned First 2000 Posts and 400 Rep Points
    Join Date
    Aug 2015
    State
    MN
    Country
    United States
    Posts
    3,866
    Mentioned
    38 Post(s)
    Tagged
    1 Thread(s)
    Likes Received
    1118
    Yes weather will effect your vehicle due to it being Turbo charged. Colder air is more dense than hot air everyday of the week. One thing to make sure is that you have a large enough intercooler to help pull heat away from the Turbo to keep it within its efficiency range that it operates the best at. When the Turbo gets too hot that can zap as much as 30whp from your overall performance. This is why you have a larger than stock intercooler to resist heat soak over the Stock unit which is mediocre at best for the stock snail. Methanol injection is another form of keeping the incoming air charge cooler than ambient Temp....but if your not paying attention to the Meth via gauge or other means and the controller quits working......Boom goes the dynamite....Engine will take a hit. This is why id rather run Aux. Fuel either in the Throttle body or 4 port Aux. fuel. With either of these you can put safety devices in place such as Stratifieds Guardian angel will notify you of failure of methanol or Aux fuel to help you from detonating. I'm sure others will chime in...but this is what I know from previous exp.....Good luck & enjoy!
    Is this your bush? Are you king of the forest?
  3. #3
    Member #
    4516
    Medals
    Join Date
    Feb 2016
    Morton Grove
    State
    IL
    Country
    United States
    Posts
    257
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    49
    Quote Originally Posted by TyphoonFiST View Post
    All supporting mods are in such as IC, intake, catted DP, catback, colder plugs, etc... The question I should have asked is, if I get a custom e-tune now will I have to get it re-tuned in the summer?
  4. #4
    Member #
    3563
    Medals
    Join Date
    Aug 2015
    State
    MN
    Country
    United States
    Posts
    3,866
    Mentioned
    38 Post(s)
    Tagged
    1 Thread(s)
    Likes Received
    1118
    Quote Originally Posted by Ceecab705 View Post
    You shouldn't have to....I run Gen2 GTX2860r and got it tuned in the late fall so I'm going test my Bravoalpha intercooler to its limits. it cant hurt to have your tuner check stuff out either just for shits.
  5. #5
    Member 165 Rep Points kivnul's Avatar
    Member #
    4220
    Medals
    Earned First 100 Posts Earned First 500 Posts Earned First 25 Rep Points Earned First 50 Rep Points Earned First 100 Rep Points
    Join Date
    Jan 2016
    Deer Park
    State
    WA
    Country
    United States
    Posts
    511
    Mentioned
    12 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    165
    When I got my tune, I made certain to finalize it when it was 90+ outside for a worst case scenario. The tuner had to keep pulling timing to get rid of knock. When I load one of those earlier tunes with current temps (near freezing) all the knock is gone.
    Edit: as a result, my plotted WHP is quite a bit lower than what alot of folks get with a similar setup to mine. I am hoping it will translate to a longer lifespan of components.
  6. #6
    New Member 20 Rep Points Tanner@FingerTuning's Avatar
    0%
    Rate Transaction
    Member #
    6571
    Medals
    Join Date
    Dec 2016
    Tulsa
    State
    AZ
    Country
    United States
    Posts
    35
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    20
    It honestly all depends on how the tune is setup, there isn't a reason the tune couldn't be setup to run year round. That's one of the biggest strong points of Ford's tuning strategy, it is designed to work in various conditions and fuel qualities. If your tune is setup with all those strategies in mind then it should be fine, if it isn't then it might need adjusting when it gets into the hotter months.
  7. #7
    Member #
    4516
    Medals
    Join Date
    Feb 2016
    Morton Grove
    State
    IL
    Country
    United States
    Posts
    257
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    49
    I went with Tune + and purchased the unlimited as Adam said he would touch it up in the summer.
Similar Threads
  1. Stratified tune affect on OEM traction control button
    By apex1 in forum Stratified Automotive Controls
    Last Post: 05-22-2018, 04:02 AM
  2. Weather stripping disinigrading!
    By KnockOff in forum Maintenance, Warranty Issues & Troubleshooting
    Last Post: 11-11-2017, 05:02 PM
  3. Stage 3 affect on injector duty cycle
    By Wcyracer in forum Performance Tuning
    Last Post: 09-19-2016, 04:17 PM
  4. Does stage 2 aka FMIC upgrade affect gas mileage?
    By jeff in forum EcoBoost Engine Upgrades
    Last Post: 03-21-2016, 07:54 AM
  5. Why lowering doesn't affect tire clearance, fo' real doe
    By justgotFiSTed in forum Suspension, Brakes & Chassis
    Last Post: 01-04-2015, 04:16 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
