Yes weather will effect your vehicle due to it being Turbo charged. Colder air is more dense than hot air everyday of the week. One thing to make sure is that you have a large enough intercooler to help pull heat away from the Turbo to keep it within its efficiency range that it operates the best at. When the Turbo gets too hot that can zap as much as 30whp from your overall performance. This is why you have a larger than stock intercooler to resist heat soak over the Stock unit which is mediocre at best for the stock snail. Methanol injection is another form of keeping the incoming air charge cooler than ambient Temp....but if your not paying attention to the Meth via gauge or other means and the controller quits working......Boom goes the dynamite....Engine will take a hit. This is why id rather run Aux. Fuel either in the Throttle body or 4 port Aux. fuel. With either of these you can put safety devices in place such as Stratifieds Guardian angel will notify you of failure of methanol or Aux fuel to help you from detonating. I'm sure others will chime in...but this is what I know from previous exp.....Good luck & enjoy!![]()
Bookmarks
